1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: EPICS for a small lab - overkill?
From: Sean Leavey - STFC UKRI via Tech-talk <[email protected]>
To: "Shen, Guobao" <[email protected]>, "Arnold, Ned D." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 18 Aug 2022 08:04:30 +0000
Thanks all - I'll get an Ubuntu LTS box put together and give it a go (without Docker)!
Sean
> -----Original Message-----
> From: Shen, Guobao <[email protected]>
> Sent: 17 August 2022 22:50
> To: Leavey, Sean (STFC,ROE,UKATC) <[email protected]>; Arnold, Ned
> D. <[email protected]>; [email protected]
> Subject: Re: EPICS for a small lab - overkill?
> If your system is small, and you don't need to worry to manage
> redeployment the same system again and again, I would probably not go
> with a container based solution.
> You would not gain that much with it, and manage the container is an extra
> maintenance burden.
> If you like Debian, you could probably go with Debian style OS, like Ubuntu
> LTS or others.
> There are many facilities have EPICS packages available on Debian-like
> system, and you don’t need to compile everything from scratch.
> But managing a small system with all source code is not really an issue as long
> as you have your version control system in place.
> I would say for long term purpose, you might want to consider Archiver
> Appliance, or Channel Archiver from SNS/ORNL.
> They have good integration with CS-Studio, which would save your effort in
> the future, when you want to link your history data with your live data.
> Thanks,
> Guobao
> On 8/17/22, 2:48 PM, "Tech-talk on behalf of Sean Leavey - STFC UKRI via
> Tech-talk" <[email protected] on behalf of tech-
> [email protected]> wrote:
>     > Sounds reasonable to me!
>     Great. Do you have any recommendations on how the single box should be
> set up? I saw some Docker images but not sure it's worth the effort over just
> building from source manually. I'd probably opt for Debian because that's
> what I know best. I'd put the IOC on the same box as the base, and use the
> Modbus support that I think is baked in already.
>     Archival is something I wanted to ask more about. It doesn't look like a
> good idea to use Archiver Appliance. Is there a lightweight archiver for a
> handful of channels (say up to 20) at 1 Hz or less? I could probably write one
> in 20 lines of Python (camonitor some channels, write values to a text file
> every N seconds, rotate file once per day), but I hope there's one that also
> supports data access, e.g. retrieving data between certain times via some
> network request... wishful thinking?
>     ________________________________________
>     From: Arnold, Ned D. <[email protected]>
>     Sent: 17 August 2022 20:41
>     To: [email protected]; Leavey, Sean (STFC,ROE,UKATC)
>     >> Has anyone used EPICS on such a small scale? Was it more trouble than
> it was worth compared to turnkey commercial solutions?
>     We use it in the labs and for small test stands all the time ... and those are
> much easier to manage than the large deployments ... you don't have to
> manage 100's of IOCs, hundreds of thousands of process variables, data
> archiving does not require a large "archiver" etc, etc, etc.  The size of the
> system greatly increases the maintenance overhead.
>     It also sounds like your I/O could be accomplished with Ethernet-based I/O
> with the IOC running whereever convenient.
>       Ned
>     From: Tech-talk <[email protected]> on behalf of Sean
>     Sent: Wednesday, August 17, 2022 02:26 PM
>     To: [email protected] <[email protected]>
>     Subject: EPICS for a small lab - overkill?
>     Hi all,
>     I'm trying to determine the feasibility of using EPICS for simple monitoring
> of a small clean room facility. We'll need to read out various sensors (particle
> counters, temperature, etc.) via Modbus over Ethernet and archive the data
> at low speed (a few times per minute maybe) and also ideally display live
> data to lab users on a GUI (e.g. MEDM or modern equivalents). We're
> probably going to have a small number of outputs as well: automated
> switching of lights, fans, motors, that kind of thing. Maybe some alarms for
> e.g. triggering a warning light if particle counts get too high. No closed loops.
>     We could probably just use LabVIEW or similar but I don't like it much and
> prefer a licence-free and open source solution that can be easily adapted as
> needed. Plus, I may clone the EPICS setup to a different lab in a different city
> that we work with, so it would be nice to be able to use a gateway to access
> and archive their channels as well.
>     Has anyone used EPICS on such a small scale? Was it more trouble than it
>     Any input would be appreciated!
>     Sean Leavey
>     This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and should
> notify the sender immediately and delete this email from your system. UK
> Research and Innovation (UKRI) has taken every reasonable precaution to
> minimise risk of this email or any attachments containing viruses or malware
> but the recipient should carry out its own virus and malware checks before
> opening the attachments. UKRI does not accept any liability for any losses or
> damages which the recipient may sustain due to presence of any viruses.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Re: EPICS for a small lab - overkill? Arnold, Ned D. via Tech-talk
Re: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Re: EPICS for a small lab - overkill? Shen, Guobao via Tech-talk
Prev: Re: RTEMS 5 Cannot Read Event Generator Hamadyk, Paul (DLSLtd, RAL, LSCI) via Tech-talk
Next: olog docker question Silver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: EPICS for a small lab - overkill? Shen, Guobao via Tech-talk
Next: Re: EPICS for a small lab - overkill? Michael Davidsaver via Tech-talk
