1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Problem with DB_INSTALLS in Makefile
From: Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Wed, 31 Aug 2022 11:43:47 -0500
Hi Mark,
On 8/31/22 9:40 AM, Mark Rivers via Tech-talk wrote:
I just tested the template file generation in asyn with this command:
/home/epics/devel/asyn/bin/linux-x86_64/makeSupport.pl -t streamSCPI test4
This is the Makefile it generated:
corvette:~/scratch/test4/test4Sup>more Makefile
TOP=..
include $(TOP)/configure/CONFIG
# Install .dbd and .db files
DB_INSTALLS += devtest4.db
DB_INSTALLS += $(TOP)/test4Sup/devtest4.proto
include $(TOP)/configure/RULES
The Makefile looks OK to me.  I am not sure why the proto file has an explicit path, and the .db file did not, since they are in the same directory.
The makeSupport.pl script is just copying the template files provided by Asyn and substituting macros. makeSupport/streamSCPI/_Name_Sup/Makefile template exactly matches the above. It looks like Janet made a change between Base-3.14.9 and 3.14.10 that modified the DB_INSTALLS rule to do what it does now.
It seems like DB_INSTALLS works if the file has a path, but does not work if the file is in the current directory?
As Michael explained, DB_INSTALLS is now used for installing local copies of files from other modules, whereas DB is used for installing files that come from this source directory. You may be able to use
DB_INSTALLS += ../devtest4.db
instead of DB, but that merely complicates the Makefile.
You'll need to adjust the template files in Asyn as appropriate.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Problem with DB_INSTALLS in Makefile Mark Rivers via Tech-talk
Prev: Re: Problem with DB_INSTALLS in Makefile Michael Davidsaver via Tech-talk
Next: Re: EPICS on ESP32 Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: RE: Problem with DB_INSTALLS in Makefile Mark Rivers via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
