1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Basic iocStats database
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Sean Leavey <sean.leavey at stfc.ac.uk>
Date: Fri, 2 Sep 2022 13:48:14 +0000
Hi Sean,
To load the iocStats records in your IOC you just need to build your application with the iocStats dbd and library files like this:
    $(DBD_NAME)_DBD += devIocStats.dbd
    PROD_LIBS        += devIocStats
And add a command like this to your IOC startup script:
dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)")
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Sean Leavey via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, September 2, 2022 8:25 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Basic iocStats database
Hi all,
Following on from my first question a couple weeks ago about the
feasibility of setting up EPICS for a small lab, I've provisioned a
Debian 11 VM and gotten EPICS Base set up. While I wait for the arrival
of the Modbus-based sensors I plan to use EPICS to read, I thought I'd
set up iocStats
(https://www.slac.stanford.edu/grp/ssrl/spear/epics/site/devIocStats/)
so I have some real world values to play with - CPU usage, etc.
Following various guides I've managed to compile the example application
with iocStats module support. However, I don't actually have any of the
records provided by iocStats configured, and that's where I've gotten
stuck. What I'd really like to see are examples of databases others have
made that make use of the various records provided by iocStats (if such
an example is provided with iocStats itself, I missed it). Ultimately I
want to be able to caget my VM's CPU load, so I can play with archiving
and plotting it later. Google has failed me so I thought I'd ask here.
So, is anyone willing to share their iocStats configurations with me?
Cheers,
Sean
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: Basic iocStats database Sean Leavey via Tech-talk
Prev: Basic iocStats database Sean Leavey via Tech-talk
Next: Re: SPI-MAXNET8000 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: Basic iocStats database Sean Leavey via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
