I am trying to build ADSupport module. I have mentioned path for BASE in RELEASE file and then run 'make' command from TOP directory. I got the following error: /usr/bin/ld: libnanohttp_stream.so: hidden symbol `xmlStrdup__internal_alias' isn't defined /usr/bin/ld: final link failed: Bad value collect2: error: ld returned 1 exit status make[3]: *** [libnanohttp_stream.so] Error 1 make[3]: Leaving directory `/epics/support/ADSupport/supportApp/xml2Src/O.linux-x86_64' make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory `/epics/support/ADSupport/supportApp/xml2Src' make[1]: *** [xml2Src.install] Error 2 make[1]: Leaving directory `/epics/support/ADSupport/supportApp' make: *** [supportApp.install] Error 2 Do anyone have a clue about this? Thanks in advance. ********************************************************************** सिद्धार्थ वर्धन प्रतिहस्त / Siddharth Vardhan Pratihast वैज्ञानिक अधिकारी / Scientific Officer कंप्यूटर एवं सूचना वर्ग / Computer and Informatics Group परिवर्ती उर्जा साइक्लोट्रॉन केंद्र / Variable Energy Cyclotron Centre परमाणु उर्जा विभाग / Department of Atomic Energy भारत सरकार / Government of India 1/ए एफ विधान नगर / 1/AF Bidhan Nagar कोलकाता - 700064 , भारत / Kolkata - 700064, India **********************************************************************
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
