It might help to mention what OS you are using, what version of base, synApps, and Area Detector, and if everything else actually compiled correctly up to this point . . .
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of
Siddharth Vardhan Pratihast via Tech-talk
Sent: Tuesday, September 13, 2022 9:06 AM
To: tech-talk at aps.anl.gov
Subject: Error while building ADSupport module
I am trying to build ADSupport module.
I have mentioned path for BASE in RELEASE file and then run 'make' command from TOP directory.
I got the following error:
/usr/bin/ld: libnanohttp_stream.so: hidden symbol `xmlStrdup__internal_alias' isn't defined
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
make[3]: *** [libnanohttp_stream.so] Error 1
make[3]: Leaving directory `/epics/support/ADSupport/supportApp/xml2Src/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/epics/support/ADSupport/supportApp/xml2Src'
make[1]: *** [xml2Src.install] Error 2
make[1]: Leaving directory `/epics/support/ADSupport/supportApp'
make: *** [supportApp.install] Error 2
Do anyone have a clue about this?
सिद्धार्थ
वर्धन
प्रतिहस्त / Siddharth Vardhan Pratihast
वैज्ञानिक
अधिकारी / Scientific Officer
कंप्यूटर
एवं
सूचना
वर्ग / Computer and Informatics Group
परिवर्ती
उर्जा
साइक्लोट्रॉन
केंद्र / Variable Energy Cyclotron Centre
परमाणु
उर्जा
विभाग / Department of Atomic Energy
भारत
सरकार / Government of India
1/ए
एफ
विधान
नगर / 1/AF Bidhan Nagar
कोलकाता - 700064 ,
भारत / Kolkata - 700064, India
- Error while building ADSupport module Siddharth Vardhan Pratihast via Tech-talk
Re: [EXTERNAL] EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Hartman, Steven via Tech-talk
RE: EPICS with Raspberry and PyEpics Zhang, Tong via Tech-talk
<2022>
2025
Implementing NDTransform plugin for areaDetector Marco A. Barra Montevechi Filho via Tech-talk
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
