On 9/15/22 20:00, lzfneu--- via Tech-talk wrote:
Dear all,
I try to use alias name for my existed pv names, part of the record are as follows:
record (calc, "test")
alias("test:alias_name")
field(INPA,"test_pv.VAL")
field(ADEL, "-1")
field(CALC, "A*10")
field(EGU, "m")
field(FLNK, "test2")
record(calc, "test2")
When I run the IOC, I received the following errors:
ErrorCan't create alias "test:alias_name" for "test" Error at or before ")" in file "db/ai.template" line XX.
And XX is the alias filed line number.
Although showed the error messages, the alias PV name "test:alias_name" can normally receive the same data as PV name "test". I have no idea how to correct the error messages.
Any help will be appreciated and thanks in advance.
What version of EPICS Base are you using?
I'm not able to replicate with 7.0.7
$ cat alias.db
field(ADEL, "-1")
field(CALC, "A*10")
field(EGU, "m")
}> $ softIoc -d alias.db
Starting iocInit
## EPICS R7.0.6.2-DEV
## Rev. R7.0.6.1-260-ga0a937d0b6ce07c20358
## Rev. Date Git: 2022-09-03 11:36:57 -0700
Forward-link uses Channel Access without pointing to PROC field
test.FLNK => test2
epics>
- Re: Question about alias name neu lzf via Tech-talk
- Question about alias name lzfneu--- via Tech-talk
RE: [EXTERNAL] Re: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Mark Rivers via Tech-talk
pyepics get_with_metadata inconstant behaviour Marco A. Barra Montevechi Filho via Tech-talk
<2022>
2025
<2022>
2025
