1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: pyepics get_with_metadata inconstant behaviour
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Cc: Lucca Bavia Cuenca Campoi <[email protected]>
Date: Fri, 16 Sep 2022 18:37:12 +0000
Good evening!
We are perceiving a strange behaviour with get_with_metadata method in pyepics here.
We have a motor record PV with defined PREC and EGU fields. We have a script that goes:
my_pv = epics.PV("MGN:B:PB01:CS7:m4")
my_dict = my_pv.get_with_metadata(use_monitor=True)
First weird behaviour: between the many values returned in my_dict, the "precision" key is associated with "None" value and the same goes for "unit" key:
{'pvname': 'MGN:B:PB01:CS7:m4', 'value': 3.56963, 'char_value': '3.56963', 'status': 0, 'ftype': 20, 'chid': 28543096, 'host': '10.10.10.38:46317', 'count': 1, 'access': 'read/write', 'write_access': True, 'read_access': True, 'severity': 0, 'timestamp': 1663352086.023605, 'posixseconds': 1663352086.0, 'nanoseconds': 23605915, 'precision': None, 'units': None, 'enum_strs': None, 'upper_disp_limit': None, 'lower_disp_limit': None, 'upper_alarm_limit': None, 'lower_alarm_limit': None, 'lower_warning_limit': None, 'upper_warning_limit': None, 'upper_ctrl_limit': None, 'lower_ctrl_limit': None, 'nelm': 1, 'type': 'time_double', 'typefull': 'time_double'}
Second weird behaviour: when executed several times, dictionaries with different number of keys are returned. Changing use_monitor=False limited the dictionary size to
{'status': 0, 'severity': 0, 'timestamp': 1663353141.426072, 'posixseconds': 1663353141.0, 'nanoseconds': 426072330, 'value': 3.56963}
and the number of keys does not vary, but now we dont have precision and unit, which would be useful. Are we doing something wrong? Where does get_with_metadata gets its information from? Shouldnt "unit" come from EGU field?
I couldnt find answers for that in the documentation. Thanks for any help 🙂
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: pyepics get_with_metadata inconstant behaviour Matt Newville via Tech-talk
Prev: Re: Question about alias name Michael Davidsaver via Tech-talk
Next: Re: mbboDirect Bx fields don't update on alarm change Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Question regarding synApps:delaygen module Mark Rivers via Tech-talk
Next: Re: pyepics get_with_metadata inconstant behaviour Matt Newville via Tech-talk
