Hi Andrew –
- If you look at how things are organized for EPICS base, it is most typical that the tests are in a separate directory. See for
example
https://github.com/epics-base/epics-base/tree/7.0/modules/libcom where you have both an src and a test directory.
That said, I’m sure it would be fine either way; it’s more of an organizational thing. - Regarding the contents and the # ADD RULES AFTER THIS LINE, they should be before that line; these are not defining new rules,
but are being used by the EPICS build system to determine what to build. See again some of the examples from EPICS base above.
- I believe that you are correct about pdbbase.
- TESTFILES, as near as I can tell, is not strictly necessary unless you are working with RTEMS. Throughout all of the EPICS base
tests, the only use of that variable is for RTEMS systems, and not otherwise. See
https://github.com/epics-base/epics-base/blob/7.0/modules/libcom/test/Makefile#L343 for example.
Cheers,
Simon
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "Wang, Andrew via Tech-talk" <tech-talk at aps.anl.gov>
Reply to: "Wang, Andrew" <wang126 at llnl.gov>
Date: Friday, 23 September 2022 at 10:02
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Subject: Unit testing for databases
I am attempting to create a unit test for an IOC I had written per project specification. I have been attempting to follow the example on this Doxygen page (EPICS
Base: Unit testing of record processing (anl.gov)), however I seem to have hit a road block. My questions are below.
In the Makefile example, are those variables for the Makefile inside the app/src directory of an IOC application?
Do the contents of the Makefile example go after the comment, which reads # ADD RULES AFTER THIS LINE?
Is pdbbase
the same global variable as described in Chapter 14 which is titled "Static Database Access"? If so, then I would need to include dbAccess.h?
What is the TESTFILES
variable for? I couldn't find an explanation in the Application Developer's Guide.
- Unit testing for databases Wang, Andrew via Tech-talk
Re: Unit testing for databases Michael Davidsaver via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 24 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
