1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Unit testing for databases
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Wang, Andrew" <wang126 at llnl.gov>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Sat, 24 Sep 2022 21:33:29 -0700
On 9/23/22 01:02, Wang, Andrew via Tech-talk wrote:
Hi all,
I am attempting to create a unit test for an IOC I had written per project specification. I have been attempting to follow the example on this Doxygen page (EPICS Base: Unit testing of record processing (anl.gov) <https://epics.anl.gov/base/R7-0/6-docs/doxygen/dbunittest.html>), however I seem to have hit a road block. My questions are below.
 1. In the Makefile example, are those variables for the Makefile inside the app/src directory of an IOC application?
I typically put tests in another directory, although is no necessary.
TESTPROD executables are only special in that they are not installed.
 2. Do the contents of the Makefile example go after the comment, which reads # ADD RULES AFTER THIS LINE?
Like most assignments, put them after
include $(TOP)/configure/CONFIG
and before
include $(TOP)/configure/RULES
 3. Is pdbbase the same global variable as described in Chapter 14 which is titled "Static Database Access"? If so, then I would need to include dbAccess.h?
Yes, and Yes.
 4. What is the TESTFILES variable for? I couldn't find an explanation in the Application Developer's Guide.
This is used to capture files which are read by test executables.
Currently only used when running tests on RTEMS/vxWorks.
Re: Unit testing for databases Wang, Andrew via Tech-talk
Prev: Re: Unit testing for databases Simon Rose via Tech-talk
Next: Re: Unit testing for databases Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 25 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
