1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: [EXTERNAL] Re: How to archive PVs regularly even if they are not updating
To: Ralph Lange <[email protected]>
Date: Mon, 26 Sep 2022 16:17:00 +0000
Hi Ralph,
Ø  For rarely-moving things, it just blows up the file with redundant identical samples.
That is not my interpretation of what Kay said:
Ø  Instead, it would for example scan once every 5 minutes, and then write whatever the most recently received sample was .. if it changed.
That means it should not fill up the file, because it does not write anything if it has not changed.
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Monday, September 26, 2022 10:47 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: [EXTERNAL] Re: How to archive PVs regularly even if they are not updating
On Mon, 26 Sept 2022 at 17:13, Kasemir, Kay <[email protected]> wrote:
MONITOR:  Channel uses monitor (for ADEL threshold) and tries to save every received value.
SCAN:  Channel uses monitor (for ADEL threshold) and then saves the most recently received value every SCAN period.
SCAN does not perform a get or get-callback every SCAN period, and it also doesn't save the time of when it was scanned.
Pardon my archiver ignorance and thanks for the explanation.
Of course: SCAN mode intends to limit the number of samples written to file for fast-moving things with small ADEL. For rarely-moving things, it just blows up the file with redundant identical samples.
Sorry for the noise.
~Ralph
Re: [EXTERNAL] Re: How to archive PVs regularly even if they are not updating Ralph Lange via Tech-talk
Re: How to archive PVs regularly even if they are not updating Shankar, Murali via Tech-talk
Re: [EXTERNAL] Re: How to archive PVs regularly even if they are not updating Kasemir, Kay via Tech-talk
Prev: Re: [EXTERNAL] Re: How to archive PVs regularly even if they are not updating Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] Re: How to archive PVs regularly even if they are not updating Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
