Hi Kay,
Thank you for the prompt reply.
Would it make sense to you to dynamically remove the PV (rpvxs::server::Server::emovePV) and then add it again (pvxs::server::Server::addPV)? Would that produce unpredictable results?
Dawood
Sent: Wednesday, September 28, 2022 11:25 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Alnajjar, Dawood <dnajjar at slac.stanford.edu>
Subject: Re: Change PVA structure dynamically during IOC operation
> I need to change a PVA structure dynamically during IOC operation. Looking at pvxs::ioc::server, I do not see an update function that allows that. Does anyone know
if this is possible?
I don't think that's possible.
If you check the protocol documentation,
https://github.com/epics-base/pvAccessCPP/wiki/protocol, you'll find that the overall structure information is exchanged once when a client connects. From then on, only a compact bitmap that indicates what changed is sent, plus the modified values.
To change the structure, the protocol would have to send the complete new structure.
Arrays can change the number of elements, but the overall structure stays the same because the protocol was optimized for this.
- Re: Change PVA structure dynamically during IOC operation Kasemir, Kay via Tech-talk
- Change PVA structure dynamically during IOC operation Alnajjar, Dawood via Tech-talk
Re: Change PVA structure dynamically during IOC operation Andrew Johnson via Tech-talk
<2022>
<2022>
ANJ, 28 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
