1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Change PVA structure dynamically during IOC operation
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "Alnajjar, Dawood" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 28 Sep 2022 18:32:23 +0000
> Would it make sense to you to dynamically remove the PV (rpvxs::server::Server::emovePV) and then add it again (pvxs::server::Server::addPV)? Would that produce unpredictable results?
Michael would know about the details of pvxs, but fundamentally you can stop the server, then restart it with the updated PV.
Clients will notice the disconnect, start searching for the missing PVs, and then connect to the newly started server where the PV now sends the updated structure during the initial steps of the subscription.
-Kay
Change PVA structure dynamically during IOC operation Alnajjar, Dawood via Tech-talk
Re: Change PVA structure dynamically during IOC operation Kasemir, Kay via Tech-talk
Re: Change PVA structure dynamically during IOC operation Alnajjar, Dawood via Tech-talk
Prev: Re: Change PVA structure dynamically during IOC operation Andrew Johnson via Tech-talk
Next: Re: [EXTERNAL] Re: Change PVA structure dynamically during IOC operation Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Change PVA structure dynamically during IOC operation Alnajjar, Dawood via Tech-talk
Next: Re: Change PVA structure dynamically during IOC operation Andrew Johnson via Tech-talk
