On 9/28/22 11:18, Alnajjar, Dawood via Tech-talk wrote:
Hi Everyone,
I need to change a PVA structure dynamically during IOC operation. Looking at pvxs::ioc::server, I do not see an update function that allows that. Does anyone know if this is possible?
Type change w/ PVA and CA protocols is accomplished by force disconnecting clients
of a PV, which can then be given a different type when they reconnect.
With the PVXS library, the SharedPV::close() method does the disconnecting,
so that a subsequent SharedPV::open() can provide a different type.
The same can be done with the pvAccessCPP library.
https://mdavidsaver.github.io/pvxs/sharedpv.html#_CPPv4N4pvxs6server8SharedPV5closeEv
That said, you mention "ioc" so you may be referring to QSRV. The process database
(aka. records) does not current have a concept of type change after records have
been loaded.
- Change PVA structure dynamically during IOC operation Alnajjar, Dawood via Tech-talk
Re: [EXTERNAL] Re: Change PVA structure dynamically during IOC operation bob dalesio via Tech-talk
asynMotorController weird behavior when using any read/write interface mask Abdalla Ahmad via Tech-talk
<2022>
2025
<2022>
2025
