Hi
Recently we got the chance to control the SMC Taurus rotary stage using the motorMicos motor record module. One of my updates was to read and write limit switches status. The command’s argument is an integer value (0-2), I implemented readIn32
and writeInt32 interfaces as usual. When moving the motor, after a while the RBV field does not update, STOP and SPMG fields do not work (The motor doesn’t stop), and it the GUI gives me “Controller Error”. When the motor reaches its destination, the controller
error clears and the RBV field is updated accordingly. I tried empty readInt32 and writeInt32 functions with only “return asynSuccess” and the behavior is still there. When I removed those interfaces, the controller works fine. To make those commands work
I moved the writeReadController and writeController functions to the poll thread and the motor works fine, motor stops at command and the RBV field is updated. Any clue on what I have missed?
Thanks!
Abdalla.
- Re: asynMotorController weird behavior when using any read/write interface mask Mark Rivers via Tech-talk
Re: Change PVA structure dynamically during IOC operation Michael Davidsaver via Tech-talk
CA library usage problem Jörn Dreyer via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
