1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: CA library usage problem
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 29 Sep 2022 14:49:54 +0200
Hi all,
i guess I have a misunderstanding how to use the user callback functions
together with a subscription to a PV variable.
In my userfunc the value of arg.status is always 1 which evaluates to a
ca_message of "Normal successful completion". But the documentation say's to
check against ECA_NORMAL witch is 0.
What am I doing wrong here.
Regards Jörn
Re: CA library usage problem Andrew Johnson via Tech-talk
Prev: asynMotorController weird behavior when using any read/write interface mask Abdalla Ahmad via Tech-talk
Next: Re: asynMotorController weird behavior when using any read/write interface mask Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: RE: asynMotorController weird behavior when using any read/write interface mask Mark Rivers via Tech-talk
Next: Re: CA library usage problem Andrew Johnson via Tech-talk
