1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values.
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Marco A. Barra Montevechi Filho" <marco.filho at lnls.br>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Torsten Bögershausen <torsten.bogershausen at ess.eu>
Cc: Augusto Yoshio Horita <augusto.horita at lnls.br>
Date: Fri, 30 Sep 2022 12:10:30 +0000
> just before iocInit in st.cmd, I see things like this:
> Parameter 8 type=asynFloat64, name=MOTOR_POSITION, value is undefined
>Parameter 9 type=asynFloat64, name=MOTOR_ENCODER_POSITION, value is undefined
> (and may be have a look at MOTOR_REC_RESOLUTION as well)
MOTOR_REC_RESOLUTION gets its value from the motor record via a CP link, so it will not be sent to the driver until after the call to iocInit.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, September 30, 2022 12:56 AM
To: Marco A. Barra Montevechi Filho <marco.filho at lnls.br>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hej Marco,
There is a possible race condition, when the IOC starts:
The record tries to read the position of the motor
from the driver, but the driver has not yet been able
to fully talk to the controller.
If I run
asynReport 10 MCU1
undefined
(You asynReport needs probably another name)
Before we dig into a possible solution:
Do you have time to try this ?
BR
/Torsten
On 2022-09-29 19:43, Marco A. Barra Montevechi Filho via Tech-talk wrote:
> Hello all. We were having problems with Pmac 2-5-16 here at LNLS. The
> problem was solved by Augusto Horita (in copy), but the behavior was
> weird and we though maybe someone here knows why it is like that or
> maybe reporting it in tech-talk would be useful for other people.
> The IOC was compiled with EPICS base 3.15.6.
> The particular instance that we were having trouble with had a set of
> axis in the PVs such as:
> BL:H:PB02:CS1:m1
> the axis was configured with
> pmacSetCoordStepsPerUnit("$(PPMAC_CS1_PORT)", 1, 1000)
> and its MRES was set to 10E-3.
> When initialized, the IOC sometimes showed the right values for .RBV and
> .VAL fields, but sometimes showed values 10 times bigger than what
> should be. Sometimes the *10 factor was only in .RBV, sometimes only in
> .VAL and sometimes in both.
> Augusto suspected this was due to failure in pmacSetCoordStepsPerUnit
> since the default scale factor is 10000 (ten times bigger than what we
> were using). So we suspected that the function was failing for whatever
> reason and defaulting the scale factor to 10000 while MRES remained in
> 10E-3. Indeed, changing MRES to 10E-4 and
>   to
> pmacSetCoordStepsPerUnit("$(PPMAC_CS1_PORT)", 1, 10000)
> Solved the problem.
> In the middle of the debug process, we struggled to find any error
> message about the suspected failure in pmacSetCoordStepsPerUnit.
> Is this absence of error message intentional? Is there a particular
> debug method we should have used?
> Has this been reported before?
> Thanks for the attention. Best regards,
> Marco
> Aviso Legal: Esta mensagem e seus anexos podem conter informações
> confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e
> considere eventual consulta ao remetente antes de copiá-la, divulgá-la
> ou distribuí-la. Se você recebeu esta mensagem por engano, por favor
> avise o remetente e apague-a imediatamente.
> Disclaimer: This email and its attachments may contain confidential
> and/or privileged information. Observe its content carefully and
> consider possible querying to the sender before copying, disclosing or
> distributing it. If you have received this email by mistake, please
> notify the sender and delete it immediately.
Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Marco A. Barra Montevechi Filho via Tech-talk
Re: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Torsten Bögershausen via Tech-talk
Prev: Re: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Torsten Bögershausen via Tech-talk
Next: Re: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 30 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
