Hello Ran,
You may also want to take a look at the PSI clone of mrfioc2 as well as supported hardware and firmware. A couple of years ago we used the following driver to test our VME-EVM-300 and VME-EVR-300 under MVME-5100 / vxWorks6.8 environment.
https://github.com/paulscherrerinstitute/mrfioc2
Lin
-----Original Messages-----
From:"Hong, Ran via Tech-talk" <tech-talk at aps.anl.gov>
Sent Time:2022-10-04 08:29:46 (Tuesday)
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc:
Subject: [SPAM] Read and Write errors with VME-EVR-300
Hello All,
I am testing a VME IOC with 1 VME-EVM-300 and 6 VME-EVR-300 boards. The CPU board is mvme-3100, and the driver is derived from mrfioc2:
I experienced many errors like missing time stamp, incorrect GTX waveform, and so on. They all stem from issues when reading from or writing to VME registries using READ32 or WRITE32 in the driver. For example, in evrMrmApp/src/drvem.cpp line
803 to 806 for latching the timestamp,
epicsUInt32
ctrl=READ32(base,
Control);
// Latch timestamp
WRITE32(base,
Control, ctrl|Control_tsltch);
It reads the control registry, modify the bit for timestamp latch, and write it back to the control registry. Occasionally, I saw the READ32 returns 0xffffffff, which is an invalid value for the control registry, and the subsequent WRITE32 results
in a mess in the EVR.
Has anyone experienced similar issues? Any suggestions to prevent or mitigate the VME I/O errors?
Thanks!
Ran Hong
- Read and Write errors with VME-EVR-300 Hong, Ran via Tech-talk
Re: Read and Write errors with VME-EVR-300 Heinz Junkes via Tech-talk
Re: Read and Write errors with VME-EVR-300 Hong, Ran via Tech-talk
<2022>
2025
Re: Read and Write errors with VME-EVR-300 Michael Davidsaver via Tech-talk
<2022>
2025
