1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: mbbo & calcout for drive position management
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 5 Oct 2022 08:57:22 +0200
On Tue, 4 Oct 2022 at 20:19, Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov> wrote:
Just in case Ralph has disconnected for the evening I'll answer: He meant to have you set DTYP to "Raw Soft Channel" since that's how the device entries spell it.
Thanks, Andrew.
Yes, my bad, sorry. The correct tag for Raw Soft support is "Raw Soft Channel".
Cheers,
~Ralph
Re: mbbo & calcout for drive position management Crisp, Daniel via Tech-talk
Re: mbbo & calcout for drive position management Andrew Johnson via Tech-talk
Prev: Re: Read and Write errors with VME-EVR-300 Hong, Ran via Tech-talk
Next: Re: Read and Write errors with VME-EVR-300 Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: mbbo & calcout for drive position management Andrew Johnson via Tech-talk
Next: Re: mbbo & calcout for drive position management Crisp, Daniel via Tech-talk
ANJ, 06 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
