1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: mbbo & calcout for drive position management
From: Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Tue, 4 Oct 2022 13:16:49 -0500
Hi Daniel,
Just in case Ralph has disconnected for the evening I'll answer: He meant to have you set DTYP to "Raw Soft Channel" since that's how the device entries spell it.
- Andrew
On 10/4/22 1:10 PM, Crisp, Daniel via Tech-talk wrote:
Hey Ralph,
(I hope I'm responding to this thread correctly, I just changed my tech-talk subscription from nscl.msu.edu to frib.msu.edu)
Well that sure makes a lot more sense, thanks!
I did run into an issue doing this, though. For reasons I don't understand, the IOC doesn't seem to like the following line in my mbbo definition:
field(DTYP, "Raw Soft")
At IOC startup, I get the following:
Can't set "REA_BTS41:STRIP_D1391:POS_SEL.DTYP" to "Raw Soft"
I figured I could take this support being there for granted.
If I grep my IOC for "Raw Soft" I get the following, which leads me to believe that it is in fact there, but maybe there's more to it?
dbd/rea-ops.dbd:device(mbbo, CONSTANT, devMbboSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(bo, CONSTANT, devBoSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(mbbi, CONSTANT, devMbbiSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(bi, CONSTANT, devBiSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(mbbiDirect, CONSTANT, devMbbiDirectSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(mbboDirect, CONSTANT, devMbboDirectSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(ai, CONSTANT, devAiSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(ao, CONSTANT, devAoSoftRaw, "Raw Soft Channel")
(these device() lines are also seen in my rea-opsApp/src/O.Common/rea-ops.dbd file)
Am I missing something here?
Thanks again!
-Dan
Complexity comes for free, Simplicity you have to work for.
Re: mbbo & calcout for drive position management Ralph Lange via Tech-talk
Re: mbbo & calcout for drive position management Crisp, Daniel via Tech-talk
Prev: Re: mbbo & calcout for drive position management Crisp, Daniel via Tech-talk
Next: Re: Read and Write errors with VME-EVR-300 Shen, Guobao via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: mbbo & calcout for drive position management Ralph Lange via Tech-talk
ANJ, 05 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
