1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Phoebus Alarm Server - Alarm acknowledgement from EPICS record
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Ian Gillingham <[email protected]>
Date: Fri, 21 Oct 2022 17:05:52 +0000
> I'm trying to find out if there's a way to send commands to the Phoebus Alarm Server from within EPICS.
Simply clear the alarm on the IOC, i.e., have the PV no longer issue an alarm, and configure the PV on the alarm server as not-latching, so it will automatically clear the alarm indication when the PV returns to OK.
We sometimes use CALC records to combine a "raw" PV with an "alarm_enable" type PV into the actual PV that's fed to the alarm server, so the "alarm_enable" type PV can then be used to stop the alarm. Or use a CALCOUT to update SZV or HIGH or HSV or ... of the record to control how it alarms.
-Kay
From: Tech-talk <[email protected]> on behalf of Ian Gillingham via Tech-talk <[email protected]>
Sent: Friday, October 21, 2022 10:16 AM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] Phoebus Alarm Server - Alarm acknowledgement from EPICS record
Alarm Server from within EPICS. I have a situation where an alarm should
be able to be acknowledged from an EPICS IOC.
Is there an API that could be tapped into to provide similar behaviour,
as if a user was using the Phoebus Alarm Tree features, but performed
from within EPICS records?
I've scoured as much as I can from searches and Phoebus documentation,
but haven't found anything.
Thanks in advance,
Ian Gillingham
Phoebus Alarm Server - Alarm acknowledgement from EPICS record Ian Gillingham via Tech-talk
Prev: Phoebus Alarm Server - Alarm acknowledgement from EPICS record Ian Gillingham via Tech-talk
Next: Re: Modbus TIMEOUT_ALARM Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: IOC make failing on a new linux build, Perl checkrelease Manoussakis, Adamandios via Tech-talk
