Subject: |
IOC make failing on a new linux build, Perl checkrelease |
"Manoussakis, Adamandios via Tech-talk" <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Tue, 25 Oct 2022 06:12:09 +0000 |
Took one of our IOCs and tried to run make on a new build, getting EPICS_BASE needs to be defined in release file but it is. This ioc will build on all of other linux machines but for some reason not this one.
Checked the release file and it’s defined, double checked to make sure HOME was echoing correctly in command prompt. Made sure that the path CDs into the directory as well.
EPICS_BASE=${HOME}/epics/base
If I write out the full path seems to compile fine but for some reason the env variable home is not making it into the release file. Feel like I am missing something obvious when we set up our other machines vs this new build.
Thanks
- Re: IOC make failing on a new linux build, Perl checkrelease Han Lee via Tech-talk
- Re: IOC make failing on a new linux build, Perl checkrelease Andrew Johnson via Tech-talk
Re: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db Marco A. Barra Montevechi Filho via Tech-talk
<2022>
2025
2026
Re: [EXTERNAL] Phoebus Alarm Server - Alarm acknowledgement from EPICS record Kasemir, Kay via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
