1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: IOC make failing on a new linux build, Perl checkrelease
From: Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Tue, 25 Oct 2022 11:05:41 -0400
Hi Adam,
On 10/25/22 2:12 AM, Manoussakis, Adamandios via Tech-talk wrote:
Took one of our IOCs and tried to run make on a new build, getting EPICS_BASE needs to be defined in release file but it is.  This ioc will build on all of other linux machines but for some reason not this one.
Checked the release file and it’s defined, double checked to make sure HOME was echoing correctly in command prompt.  Made sure that the path CDs into the directory as well.
EPICS_BASE=${HOME}/epics/base
If I write out the full path seems to compile fine but for some reason the env variable home is not making it into the release file.  Feel like I am missing something obvious when we set up our other machines vs this new build.
The RELEASE file is not just read by GNUmake, we have our own parser and that explicitly does not support the use of environment variables in RELEASE files, please use an absolute path. This was to ensure that settings that could have been added to the environment by hand can't affect your build (which you might not discover until months later when it doesn't work).
Disabling the checkRelease tests like Han suggests removes the seat-belt protection which the EPICS build system provides, use that at your own risk.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: IOC make failing on a new linux build, Perl checkrelease Han Lee via Tech-talk
Re: IOC make failing on a new linux build, Perl checkrelease Michael Davidsaver via Tech-talk
RE: IOC make failing on a new linux build, Perl checkrelease Manoussakis, Adamandios via Tech-talk
Prev: Re: IOC make failing on a new linux build, Perl checkrelease Han Lee via Tech-talk
Next: Re: IOC make failing on a new linux build, Perl checkrelease Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 25 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
