Hello all!
Im reading through the EPICS motor record to search for a field similar to .RLV. If i understand correctly, the .RLV will do something similar to summing the caputted value to .VAL instead of directly putting it into .VAL.
Is there a field that sums itself with .RBV instead and then puts this value into .VAL?
Example of expected behavior:
caget MOTOR.RBV
MOTOR.RBV 0.5
caget MOTOR.VAL
MOTOR.VAL 2 #Lets say that for some reason .VAL and .RBV are not in sync.
caput MOTOR.MISTERIOUS_FIELD 0.5
#wait for some time...
caget MOTOR.RBV
MOTOR.RBV 1
caget MOTOR.VAL
MOTOR.VAL 1
Sorry if the question is trivial but i couldnt find anything in the documentation. Thanks!
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta
ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying
to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Re: Motor record: motion relative to .RBV Torsten Bögershausen via Tech-talk
- Re: Motor record: motion relative to .RBV Kevin Peterson via Tech-talk
Software Engineer Position at APS Shen, Guobao via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 01 Nov 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
