1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Motor record: motion relative to .RBV
From: Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov>
To: "Marco A. Barra Montevechi Filho" <marco.filho at lnls.br>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 1 Nov 2022 10:23:26 -0500
Marco,
The motor record will tell device support to send relative move commands with displacements relative to the readback position, instead of absolute move commands, to the controller if the following conditions are met:
1. RTRY != 0
2. RMOD != "In-Position"
3. UEIP = YES or URIP = YES
The default RMOD setting is not "In-Position", so all that should be required is to set RTRY > 0 and set UEIP = YES (assuming ERES is set correctly).
It is important to note that not all drivers implement relative moves (motorPIGCS2 is the first that comes to mind).
Kevin
On 10/28/22 14:40, Marco A. Barra Montevechi Filho via Tech-talk wrote:
Hello all!
Im reading through the EPICS motor record to search for a field similar to .RLV. If i understand correctly, the .RLV will do something similar to summing the caputted value to .VAL instead of directly putting it into .VAL.
Is there a field that sums itself with .RBV instead and then puts this value into .VAL?
Example of expected behavior:
caget MOTOR.RBV
MOTOR.RBV         0.5
caget MOTOR.VAL
MOTOR.VAL         2  #Lets say that for some reason .VAL and .RBV are not in sync.
caput MOTOR.MISTERIOUS_FIELD 0.5
#wait for some time...
caget MOTOR.RBV
MOTOR.RBV            1
caget MOTOR.VAL
MOTOR.VAL             1
Sorry if the question is trivial but i couldnt find anything in the documentation. Thanks!
Marco
Motor record: motion relative to .RBV Marco A. Barra Montevechi Filho via Tech-talk
Prev: calc type record question Meddage, Varuna via Tech-talk
Next: ADEiger : master file not found John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: RE: Motor record: motion relative to .RBV Pearson, Matthew via Tech-talk
Next: phoebus display runtime chenhuiting--- via Tech-talk
ANJ, 01 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
