1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: phoebus display runtime
From: chenhuiting--- via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>
Date: Mon, 31 Oct 2022 15:53:50 +0800
Dearall
I have a problem that java processes always occupy too much CPU, causing the computer system to crash,while phoebus is running.
After restarting the computer or phoebus software, the system becomes smooth.  However,the computer becomed sluggish after more than ten hours of uptime when phoebus’s file is display runtime. There is only one setting for address in the aile settings.ini.  I have tried different versions of phoebus, but the same situation has occurred. I used jstack, top -H, and matching pid with nid to find out what is happening. I found that the culprit was QuantumRenderer with 95+% CPU usage.
The application is using a 64Bit version of centos 7 with base3-15-5. And the current version is phoebus-4.6.6 with jdk-16.0.1.
I can't figure out where should I look to find out what is the problem...
How can I solve this problem?
Thanks
chenhuiting at zjlab.org.cn
  CHEN Huiting
  Beamline Contrl Group, SSRF
  No. 239 Zhangheng Road, Pudong, Shanghai
RE: phoebus display runtime Engbretson, Mark S. via Tech-talk
Re: [EXTERNAL] phoebus display runtime Kasemir, Kay via Tech-talk
Prev: Re: Motor record: motion relative to .RBV Torsten Bögershausen via Tech-talk
Next: RE: Motor record: motion relative to .RBV Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Motor record: motion relative to .RBV Kevin Peterson via Tech-talk
Next: RE: phoebus display runtime Engbretson, Mark S. via Tech-talk
ANJ, 01 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
