1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: [EXTERNAL] phoebus display runtime
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>, "chenhuiting at zjlab.org.cn" <chenhuiting at zjlab.org.cn>
Date: Mon, 31 Oct 2022 15:25:11 +0000
Is everything that you describe happening on the same host, or are you remotely viewing the display via ssh/remote-X or VNC or Thinlinc or ...?
Rendering via a remote connection tends to be slower.
As long as you render locally, i.e. cs-studio is running on the host that has the actual display/mouse/keyboard, try to figure out what part of the display is causing the slowdown.
For example, delete some plots and check if that makes a difference.
Finally, once you narrowed down what is causing the slowdown, you can try running with jvisualvm or jprofiler to see where it is spending its time.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of chenhuiting--- via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, October 31, 2022 3:53 AM
Subject: [EXTERNAL] phoebus display runtime
Dearall
I have a problem that java processes always occupy too much CPU, causing the computer system to crash,while phoebus is running.
After restarting the computer or phoebus software, the system becomes smooth.  However,the computer becomed sluggish after more than ten hours of uptime when phoebus’s file is display runtime. There is only one setting for address in the aile settings.ini.  I have tried different versions of phoebus, but the same situation has occurred. I used jstack, top -H, and matching pid with nid to find out what is happening. I found that the culprit was QuantumRenderer with 95+% CPU usage.
The application is using a 64Bit version of centos 7 with base3-15-5. And the current version is phoebus-4.6.6 with jdk-16.0.1.
I can't figure out where should I look to find out what is the problem...
How can I solve this problem?
Thanks
  CHEN Huiting
  Beamline Contrl Group, SSRF
  No. 239 Zhangheng Road, Pudong, Shanghai
phoebus display runtime chenhuiting--- via Tech-talk
Prev: RE: phoebus display runtime Engbretson, Mark S. via Tech-talk
Next: calc type record question Meddage, Varuna via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: RE: phoebus display runtime chenhuiting--- via Tech-talk
Next: Re: Re: [EXTERNAL] phoebus display runtime Kasemir, Kay via Tech-talk
ANJ, 08 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
