1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: calc type record question
From: Pete Jemian via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Tue, 1 Nov 2022 11:53:34 -0500
and eliminate white space in the .CALC expression
On 11/1/2022 11:46 AM, Arnold, Ned D. via Tech-talk wrote:
 > Try to simplify your expression,
and use spare INP fields to hold constants ... C>=1.75&&C  => C>=F&&C   (INPF=1.75)
*From:* Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Kasemir, Kay via Tech-talk <tech-talk at aps.anl.gov>
*Sent:* Tuesday, November 1, 2022 11:13 AM
*To:* tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Meddage, Varuna <meddage at phys.ksu.edu>
*Subject:* Re: calc type record question
The length of the CALC field is limited something around 80 characters.
Try to simplify your expression, for example by removing some parentheses that are good for readability but not strictly necessary.
*From:* Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Meddage, Varuna via Tech-talk <tech-talk at aps.anl.gov>
*Sent:* Tuesday, November 1, 2022 11:08 AM
*Subject:* [EXTERNAL] calc type record question
I have following "calc" type record in one of my .db files.
record(calc,"$(detector)_wib$(crate)0$(wib)/calc")
       field(SCAN,"5 second")
       field(CALC,"((A>=4.6&&A<=5.2)&&(B>=4.6&&B<=5.2)&&(C>=1.75&&C<=1.80)&&(D>=3.2&&D<=3.4)&&(E>=0.7&&E<=2.0))?1:0")
       field(INPA,"$(detector)_wib$(crate)0$(wib)/vcc")
       field(INPB,"$(detector)_wib$(crate)0$(wib)/v1")
       field(INPC,"$(detector)_wib$(crate)0$(wib)/v2")
       field(INPD,"$(detector)_wib$(crate)0$(wib)/v3")
       field(INPE,"$(detector)_wib$(crate)0$(wib)/v4")
       field(DESC,"")
       field(HIHI,"")
       field(HIGH,"")
       field(LOW,"")
       field(LOLO,"")
       field(MDEL,"-1")
       field(ADEL,"-1")
       field(OOPT,"Every Time")
       field(PREC,"6")
When I run the EPICS, then I get an error message saying "String is too long" complaining about the expression, I inserted inside the "CALC" field in this record. But when I reduced the number of input PVs of this record from 5 to 4 and rewrite the expression inside "CALC" field, then there is no error.
Is there maximum number of input PVs, that I can use inside a "calc" type record ?
Any help to understand this issue is highly appreciated.
Thanks
Varuna Meddage
Pete R. Jemian, Ph.D.                 <jemian at anl.gov>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
      Education is the one thing for which people
         are willing to pay yet not receive.
calc type record question Meddage, Varuna via Tech-talk
Re: calc type record question Kasemir, Kay via Tech-talk
Re: calc type record question Arnold, Ned D. via Tech-talk
Prev: Re: calc type record question Arnold, Ned D. via Tech-talk
Next: RE: calc type record question GAGET Alexis via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 02 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
