Your information of the filenames is wrong.
It looks like you have copied and pasted from a document (Character coding!)?
File name might look like this: /home/test/work/vxconfig/default/vxWorks
Startup script like this: /home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd
(And please note the length limitation and use soft-links if necessary - > shorter filenames).
Heinz
> On 4. Nov 2022, at 04:02, whitetiger1123 via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Hello,
> I’m trying to serial communication MVME6100 and set up this board to booting well.
> So when I’m trying to start putty and this MVME6100 board booting very nice.
> First step booting->
> CPU:Motorola MVME6100-0173 – MPC 7457
> Version: VxWorks5.5.1
> BSP version: 1.2/5
> Creation date: Nov 4 2008, 16:13:29
> Press any key to stop auto-boot …
> 6
> [VxWorks Boot]: c
> Boot device : geisc
> Unit number : 0
> Processor number: 0
> Host name: host
> File name : vxworks file path (/home/test/work/vxconfig/default/vxWorks)
> Inet on ethernet : cpu board ip:subnetmask (10.4.49.67:ffffff00)
> Host inet : server ip
> User : test
> ftp password : test
> Flags : 0x0
> Startup script : epics motor module st.cmd file path (/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd
> And then press enter key, It shows me error like this
> WARNING:Bootline longer than BOOT_LINE_SIZE (255 bytes). Not saved to NVRAM.
> I can see my setting value is like this,
> [VxWorks Boot]: p
> Boot device : geisc
> Unit number : 0
> Processor number: 0
> Host name: host
> File name : vxworks file path => (??????????????????/home/test/w?o?rk/vxc??onf??ig/default/v???????xWorks)
> Inet on ethernet : cpu board ip:subnetmask =>(??????10.4.49.67:ffffff00)
> User : test => ????test
> ftp password : test
> Flags : 0x0
> Startup script : epics motor module st.cmd file path =>(/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd
> Do you guys have any solutions to resolve this problem? I really need help.
> Thank you.
smime.p7s
Description: S/MIME cryptographic signature
- MVME6100 booting error(putty) whitetiger1123 via Tech-talk
Re: NTNDArray with attributes using QSRV group Pas Joao Paulo Martins via Tech-talk
Processing a record with asynPortDriver Sobhani, Alex via Tech-talk
<2022>
2025
<2022>
2025
