1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Processing a record with asynPortDriver
To: "[email protected]" <[email protected]>, "Sobhani, Alex" <[email protected]>
Date: Fri, 4 Nov 2022 19:22:55 +0000
Hi Alex,
> Is there a function that I can call like this: "processRecord(param);", and it will just process the record associated with that param?
asynPortDriver does not actually know anything about processing records.  It can be used in C++ code that is not running in an IOC application at all.  So the real question is whether it is possible to force callbacks to the asynPortDriver client, which is typically, but not always, EPICS asyn device support.
The answer is that the asynPortDriver parameter library caches value, status, and severity and only does callbacks if any of those has changed.  As you indicated you can force a callback like this, which is admittedly rather ugly.
getIntegerParam(param, &currentValue);
setIntegerParam(param, currentValue+1);
setIntegerParam(param, currentValue);
callParamCallbacks();
You could also toggle the value of status by replacing get/setIntegerParam with get/setParamStatus.
From: Tech-talk <[email protected]> on behalf of Sobhani, Alex via Tech-talk <[email protected]>
Sent: Friday, November 4, 2022 1:45 PM
To: [email protected] <[email protected]>
Subject: Processing a record with asynPortDriver
I can use setIntegerParam(param, val); to change the value of a record,
and if val is different from the PV's current value, the record will get
processed. But if val is the same as the PV's current value the record
will not get processed. So if I want to process a record I have to find
out its current value using getIntegerParam, and then set it to
something other than this.
and it will just process the record associated with that param? I can
make one using the procedure I described in the previous paragraph but I
am sure there is a better way to do this.
Alex
Re: [SPAM] Re: Processing a record with asynPortDriver Wang, Lin via Tech-talk
Processing a record with asynPortDriver Sobhani, Alex via Tech-talk
Prev: Re: Phoebus Alarm Log Table docs William F Badgett Jr via Tech-talk
Next: Re: [SPAM] Re: Processing a record with asynPortDriver Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Processing a record with asynPortDriver Sobhani, Alex via Tech-talk
