1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Thu, 10 Nov 2022 09:43:09 +0100
On Thu, 10 Nov 2022 at 09:16, Amit Chauhan via Tech-talk <tech-talk at aps.anl.gov> wrote:
Try writing only 'vxWorks' for the field 'File name:'  as below
File name : vxWorks
Background:
The file name is usually relative to the root of the download area of the tftp server (probably set as TFTP_DIRECTORY in the server configuration). On the server, the file should really be located below that directory (soft links on the server pointing outside the tftp area won't work).
Cheers,
~Ralph
Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Johnson, Andrew N. via Tech-talk
vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error whitetiger1123 via Tech-talk
Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Amit Chauhan via Tech-talk
Prev: Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Amit Chauhan via Tech-talk
Next: Altering motor resolution via MRES field Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Johnson, Andrew N. via Tech-talk
ANJ, 10 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
