1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Altering motor resolution via MRES field
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Cc: SOL <[email protected]>
Date: Thu, 10 Nov 2022 12:51:58 +0000
Hello all,
We are using a micosIOC (https://github.com/epics-motor/motorMicos.git) to control an UPR-160 motor: https://www.pi-usa.us/fileadmin/user_upload/pi_us/files/product_datasheets/Air_Bearing_Rotation_Stages_UPR-Air_Family.pdf
According to the motor technical data, its resolution can go down to 0.00004 degrees. The current IOC has a motor with .MRES=0.04 deg, so we cant make movements smaller than this. When i caput MRES to 0.004, i can caput .VAL from 0.1 to 0.105, for example, and the motor will move.
However, although the .RBV shows the movement incrementing 0.005 degrees, the actual observed movement is of 0.05 degrees. In other words: changing the motor MRES to ten times lower makes the motor move ten times more than what is commanded.
We (me and Augusto Horita) also tried using the SMChydraChangeResolution("Hydra1", 1, 0.004) function and leaving MRES as 0.004 in substitutions, but the same behavior was found.
Am i doing something wrong?
Thanks for any help,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Altering motor resolution via MRES field Kevin Peterson via Tech-talk
Prev: Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Ralph Lange via Tech-talk
Next: Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Johnson, Andrew N. via Tech-talk
Next: Re: Altering motor resolution via MRES field Kevin Peterson via Tech-talk
