Marco,
Please run the following command on the ioc shell and share the output
for the relevant axis:
asynReport 1 Hydra1
The info printed by the axis report method is likely to be relevant:
https://github.com/epics-motor/motorMicos/blob/1d643c3c50c7c798a44f2e6d7806721eac8b136c/micosApp/src/SMChydraAxis.cpp#L78-L87
Kevin
On 11/10/22 06:51, Marco A. Barra Montevechi Filho via Tech-talk wrote:
Hello all,
We are using a micosIOC (https://github.com/epics-motor/motorMicos.git
<https://github.com/epics-motor/motorMicos.git>) to control an UPR-160
motor:
https://www.pi-usa.us/fileadmin/user_upload/pi_us/files/product_datasheets/Air_Bearing_Rotation_Stages_UPR-Air_Family.pdf
<https://www.pi-usa.us/fileadmin/user_upload/pi_us/files/product_datasheets/Air_Bearing_Rotation_Stages_UPR-Air_Family.pdf>
According to the motor technical data, its resolution can go down to
0.00004 degrees. The current IOC has a motor with .MRES=0.04 deg, so we
cant make movements smaller than this. When i caput MRES to 0.004, i can
caput .VAL from 0.1 to 0.105, for example, and the motor will move.
However, although the .RBV shows the movement incrementing 0.005
degrees, the actual observed movement is of 0.05 degrees. In other
words: changing the motor MRES to ten times lower makes the motor move
ten times more than what is commanded.
We (me and Augusto Horita) also tried using
the SMChydraChangeResolution("Hydra1", 1, 0.004) function and leaving
MRES as 0.004 in substitutions, but the same behavior was found.
Am i doing something wrong?
Thanks for any help,
Marco
- Altering motor resolution via MRES field Marco A. Barra Montevechi Filho via Tech-talk
Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Johnson, Andrew N. via Tech-talk
Re: Altering motor resolution via MRES field Kevin Peterson via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 11 Nov 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
