1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Allied Vision Alvium Camera streaming issue
From: Sandeep Kumar Malu - STFC UKRI via Tech-talk <[email protected]>
Date: Tue, 15 Nov 2022 06:56:56 +0000
Hi Mark,
Thank you for the suggestions. Its working with passive scan. On doing the $(P)$(R)GC_AcquisitionStart.PROC before $(P)$(R)Acquire Start makes the camera streaming on Software Trigger.
Earlier, I ignored to PROC $(P)$(R)GC_AcquisitionStart and was only relying on $(P)$(R)Acquire to get the thing working.
Thanks
Sandeep
Sent: 15 November 2022 05:41
To: Malu, Sandeep Kumar (-,RAL,CLF) <[email protected]>
Cc: [email protected] <[email protected]>
Subject: RE: Allied Vision Alvium Camera streaming issue
Hi Sandeep,
I get this message on IOC start
2022/11/14 05:13:00.331 Param[ACQ_PERIOD] GenICamFeature::write: node AcquisitionFrameRate is not writable
2022/11/14 05:13:00.359 Param[GC_FRAMERATE_ENABLE] GenICamFeature::write: node AcquisitionFrameRateEnable is not writable
2022/11/14 05:13:00.387 VimbaFeature:writeEnumIndex: ERROR calling SetValue error=-11
Those messages are not serious.  They just mean that the camera is not currently in a mode where you are allowed to change AcquisitionFrameRate.  That typically happens because AcquisitionFrameRateAuto is true.  You can ignore them for now.
I have 2 suggestions for investigating the problem of the camera not acquiring frames.
-          In the upper-right corner of the OPI screen Status rate is set to Passive.  You should set it to 1 second.  Then you will get statistics about dropped frames, underrun frames, etc.  That is important information.
-          The screen you are using appears to be one that you manually edited from the ADVimba.adl that is in the ADVimba distribution.  Please run with the original screen, which has some additional diagnostic information, and send a screen shot of that.
From: Tech-talk <[email protected]> On Behalf Of Sandeep Kumar Malu - STFC UKRI via Tech-talk
Sent: Monday, November 14, 2022 3:00 AM
To: EPICS tech-talk <[email protected]>
Subject: Allied Vision Alvium Camera streaming issue
Hello
I have Allied Vision Alvium G1-2460m Camera and using ADVimba driver to interface the same. I can write/read all other camera parameters but can't see image streaming (the array counter is not running up). I have followed this link to create template files. I get this message on IOC start
The contents of st.cmd are
#   ADVimba driver
ADVimbaConfig("TEST1-CAM:CAM", 192.168.0.30, 0, 0,0)
dbLoadRecords("/usr/local/epics/support/areaDetector/current/ADVimba/db/vimba.template", "P=TEST1-CAM:,R=cam1:,PORT=TEST1-CAM:CAM")
dbLoadRecords("/usr/local/epics/support/areaDetector/current/ADGenICam/db/AVT_AlviumG1.template", "P=TEST1-CAM:,R=cam1:,PORT=TEST1-CAM:CAM")
# standard arrays plugin
NDStdArraysConfigure("TEST1-CAM:Image", 3, 0, "TEST1-CAM:CAM", 0, 0)
dbLoadRecords("/usr/local/epics/support/areaDetector/current/ADCore/db/NDStdArrays.template", "P=TEST1-CAM:,R=image1:,PORT=TEST1-CAM:Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=TEST1-CAM:CAM,TYPE=Int8,FTVL=UCHAR,NELEMENTS=24551424")
FYI, The software trigger source is selected which should capture the frame on every software trigger. Detector state is always in waiting state. I have attached opi screenshot to confirm that camera interface works well. Any suggestions would be appreciated.
Thanks
Sandeep
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
RE: Allied Vision Alvium Camera streaming issue Mark Rivers via Tech-talk
Allied Vision Alvium Camera streaming issue Sandeep Kumar Malu - STFC UKRI via Tech-talk
Prev: Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
Next: RE: Epics Archiver Appliance requests and DST/Timezones Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: Allied Vision Alvium Camera streaming issue Mark Rivers via Tech-talk
Next: RE: Allied Vision Alvium Camera streaming issue Mark Rivers via Tech-talk
