1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Allied Vision Alvium Camera streaming issue
From: Sandeep Kumar Malu - STFC UKRI via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 14 Nov 2022 08:59:39 +0000
Hello
I have Allied Vision Alvium G1-2460m Camera and using ADVimba driver to interface the same. I can write/read all other camera parameters but can't see image streaming (the array counter is not running up). I have followed this link to create template files. I get this message on IOC start
2022/11/14 05:13:00.331 Param[ACQ_PERIOD] GenICamFeature::write: node AcquisitionFrameRate is not writable
2022/11/14 05:13:00.359 Param[GC_FRAMERATE_ENABLE] GenICamFeature::write: node AcquisitionFrameRateEnable is not writable
2022/11/14 05:13:00.387 VimbaFeature:writeEnumIndex: ERROR calling SetValue error=-11
The contents of st.cmd are
#   ADVimba driver
ADVimbaConfig("TEST1-CAM:CAM", 192.168.0.30, 0, 0,0)
dbLoadRecords("/usr/local/epics/support/areaDetector/current/ADVimba/db/vimba.template", "P=TEST1-CAM:,R=cam1:,PORT=TEST1-CAM:CAM")
dbLoadRecords("/usr/local/epics/support/areaDetector/current/ADGenICam/db/AVT_AlviumG1.template", "P=TEST1-CAM:,R=cam1:,PORT=TEST1-CAM:CAM")
# standard arrays plugin
NDStdArraysConfigure("TEST1-CAM:Image", 3, 0, "TEST1-CAM:CAM", 0, 0)
dbLoadRecords("/usr/local/epics/support/areaDetector/current/ADCore/db/NDStdArrays.template", "P=TEST1-CAM:,R=image1:,PORT=TEST1-CAM:Image,ADDR=0,TIMEOUT=1,NDARRAY_PORT=TEST1-CAM:CAM,TYPE=Int8,FTVL=UCHAR,NELEMENTS=24551424")
FYI, The software trigger source is selected which should capture the frame on every software trigger. Detector state is always in waiting state. I have attached opi screenshot to confirm that camera interface works well. Any suggestions would be appreciated.
Thanks
Sandeep
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Attachment: AlviumCameraDebug1.png
Description: AlviumCameraDebug1.png
Re: Allied Vision Alvium Camera streaming issue Andy Foster via Tech-talk
RE: Allied Vision Alvium Camera streaming issue Mark Rivers via Tech-talk
Re: Allied Vision Alvium Camera streaming issue Wang Xiaoqiang via Tech-talk
Prev: Disable PVs processing based on some condition Abdalla Ahmad via Tech-talk
Next: Re: Disable PVs processing based on some condition Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Disable PVs processing based on some condition Rolf Keitel via Tech-talk
Next: Re: Allied Vision Alvium Camera streaming issue Andy Foster via Tech-talk
