1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Disable PVs processing based on some condition
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 14 Nov 2022 10:10:25 +0100
On Mon, 14 Nov 2022 at 09:10, Abdalla Ahmad via Tech-talk <tech-talk at aps.anl.gov> wrote:
I would like to disable processing for certain PVs based on some condition, I used the DISA field by writing 1 to it in a dfanout record from a calcout record (OUT field). The setup is working fine but with a strange behavior (which might be expected). Writing anything to DISA does not take effect until the PV is processed, so I had to make another fanout record only to process those PVs whenever the calcout record is processed (FLNK). Now assume if the condition is met and the PVs got disabled, if you write anything to the PV, it will not process it but on the next change from calcout. This can be problematic in certain setups. Is there any way to avoid writing at all when the PV is disabled? Or a better way to disable PVs? Thanks.
What about skipping the dfanouts / fanouts and just pointing the SDIS links of all to-be-conditionally-disabled records to the condition calc? If you make these SDIS links CP, the target records will be processed when the disable condition changes.
Cheers,
~Ralph
RE: Disable PVs processing based on some condition Abdalla Ahmad via Tech-talk
Prev: Allied Vision Alvium Camera streaming issue Sandeep Kumar Malu - STFC UKRI via Tech-talk
Next: Re: Disable PVs processing based on some condition Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Disable PVs processing based on some condition Abdalla Ahmad via Tech-talk
Next: RE: Disable PVs processing based on some condition Abdalla Ahmad via Tech-talk
ANJ, 16 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
