Hello Ralph
Thanks for your suggestion. This works well and even suitable as a runtime configuration without the need for an IOC but it has the same behavior as with the
dfanout setup. I set SDIS to “TestPV CP” and DISV to the disable value and the PV does not get processed while TestPV equal DISV, If I change the PV while it is disabled, it will be processed with that value when TestPV is not equal to DISV.
Best Regards,
Abdalla.
On Behalf Of Ralph Lange via Tech-talk
Sent: Monday, November 14, 2022 12:10 PM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Subject: Re: Disable PVs processing based on some condition
I would like to disable processing for certain PVs based on some condition, I used the DISA field by writing 1 to it in a dfanout record from a calcout
record (OUT field). The setup is working fine but with a strange behavior (which might be expected). Writing anything to DISA does not take effect until the PV is processed, so I had to make another fanout record only to process those PVs whenever the calcout
record is processed (FLNK). Now assume if the condition is met and the PVs got disabled, if you write anything to the PV, it will not process it but on the next change from calcout. This can be problematic in certain setups. Is there any way to avoid writing
at all when the PV is disabled? Or a better way to disable PVs? Thanks.
What about skipping the dfanouts / fanouts and just pointing the SDIS links of all to-be-conditionally-disabled records to the condition calc? If you make these SDIS links CP, the target records will be processed when the disable condition
changes.
- Disable PVs processing based on some condition Abdalla Ahmad via Tech-talk
- Re: Disable PVs processing based on some condition Ralph Lange via Tech-talk
RE: Epics Archiver Appliance requests and DST/Timezones Abdalla Ahmad via Tech-talk
Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
<2022>
2025
Re: Disable PVs processing based on some condition Maren Purves via Tech-talk
<2022>
2025
ANJ, 16 Nov 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
