Hello
I would like to disable processing for certain PVs based on some condition, I used the DISA field by writing 1 to it in a dfanout record
from a calcout record (OUT field). The setup is working fine but with a strange behavior (which might be expected). Writing anything to DISA does not take effect until the PV is processed, so I had to make another fanout record only to process those PVs whenever
the calcout record is processed (FLNK). Now assume if the condition is met and the PVs got disabled, if you write anything to the PV, it will not process it but on the next change from calcout. This can be problematic in certain setups. Is there any way to
avoid writing at all when the PV is disabled? Or a better way to disable PVs? Thanks.
Abdalla Al-Dalleh
Control Engineer
SESAME (Synchrotron-light for Experimental Science and Applications in the Middle East)
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
[email protected]
www.sesame.org.jo
- Re: Disable PVs processing based on some condition Ralph Lange via Tech-talk
- Re: Disable PVs processing based on some condition Maren Purves via Tech-talk
- Re: Disable PVs processing based on some condition Rolf Keitel via Tech-talk
Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
Allied Vision Alvium Camera streaming issue Sandeep Kumar Malu - STFC UKRI via Tech-talk
<2022>
2025
2026
Re: RE: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
