1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file
To: "tynan ford" <[email protected]>, "liu, wanming" <[email protected]>
Date: Wed, 16 Nov 2022 10:48:30 +0800 (GMT+08:00)
Many thanks for all your tips. It seems that phoebusgen is used to generate widgets.I need to write pv value into a xml file, so using etree maybe better. That would be great if there was an example.
Xuan
-----原始邮件-----
发件人:"Tynan Ford" <[email protected]>
发送时间:2022-11-16 00:56:24 (星期三)
收件人: "Liu, Wanming" <[email protected]>
抄送: "吴煊" <[email protected]>, "kasemir, kay" <[email protected]>, tech-talk <[email protected]>
主题: Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file
I would not necessarily recommend doing this but you can see an example (exampleInPhoebus files) of creating XML file in jython here: https://github.com/als-epics/phoebusgen/tree/master/examples
On Tue, Nov 15, 2022 at 8:36 AM Liu, Wanming via Tech-talk <[email protected]> wrote:
The bob file is a xml file.  So you can use etree from lxml package to manipulate the file with python.
From: Tech-talk <[email protected]> On Behalf Of ?? via Tech-talk
Sent: Monday, November 14, 2022 7:58 PM
To: kasemir, kay <[email protected]>
Subject: Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file
I'm sorry I didn't make myself clear. I wish to know how to create and write XML file using jython/python script in phoebus? Is there a way to find and replace charactors especially pv_names in xxx.bob file?
Xuan
-----原始邮件-----
发件人:"Kasemir, Kay" <[email protected]>
发送时间:2022-11-14 22:27:56 (星期一)
收件人: tech-talk <[email protected]>, "吴煊" <[email protected]>
抄送:
> Is there "Find/Replace" function still in phoebus? It's very useful for replacing pv names or other things in CSS. Another question I'd like to ask:how to create and write XML file in phoebus? I haven't see it in display builder examples. Any advice or suggestions will be grately appretiated
Yes, one advantage of the XML file format is that it allows creating or modifying theses files outside of the graphical editor.
We don't try to include a complete XML editor in phoebus, but you can easily add an OS-specific editor to the context menu so that you can then open a display file from the phoebus file browser via the context menu.
For example, on Linux you can add a reference to the plain "gedit" text editor like this, so it can then be used to open *.bob or *.opi files and for example perform PV name replacements:
org.phoebus.framework.workbench/external_app_text=Text Editor,txt|dat|tab|py|ini|def|db|xml|xsl|css|cmd|sh|st|log|out|md|tex|shp|bob|opi|pvs|edl,gedit
You could also register VS code or another more XML-aware editor just for *.bob like that.
For a general python package that generates display files outside of phoebus, see https://github.com/als-epics/phoebusgen
-Kay
Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file Pete Jemian via Tech-talk
Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file Kasemir, Kay via Tech-talk
Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
RE: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file Liu, Wanming via Tech-talk
Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file Tynan Ford via Tech-talk
Prev: RE: Epics Archiver Appliance requests and DST/Timezones Manoussakis, Adamandios via Tech-talk
Next: Re: Epics Archiver Appliance requests and DST/Timezones Pete Jemian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: RE: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file Liu, Wanming via Tech-talk
Next: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file Pete Jemian via Tech-talk
