1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file
From: Pete Jemian via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 15 Nov 2022 21:58:30 -0600
Your challenge when writing or replacing a PV value into an xml file is locating _which_ PV value to be replaced, finding the correct  the xml node to be edited.  Assuming the XML file uses more than a single PV, you'd need a way of finding the correct one.
That complicates the simple example you request.  For example, one of the widgets in the synApps/std timer screen has this xml:
  <widget type="choice" version="2.0.0">
    <name>choice button #23</name>
    <pv_name>$(P)timer$(N):Go</pv_name>
    <x>5</x>
    <y>34</y>
    <width>70</width>
    <height>35</height>
    <background_color>
      <color red="115" green="223" blue="255">
      </color>
    </background_color>
    <horizontal>false</horizontal>
    <border_alarm_sensitive>false</border_alarm_sensitive>
    <items>
      <item>Item 1</item>
      <item>Item 2</item>
    </items>
  </widget>
The .bob file has these PVs:
(base) ~$ grep pv_name /usr/local/epics/synApps6.1/support/std-R3-6-2/stdApp/op/bob/autoconvert/timer.bob
    <pv_name>$(P)timer$(N):elapsedSecs</pv_name>
You could use the findall() (https://lxml.de/tutorial.html#elementpath) method to locate the `pv_name` nodes but you must still decide which to edit.  The macros (with definitions unique to this file) are defined elsewhere in the file.
Describe for us what you plan to do (create a new .bob file from an empty file or edit an existing file that you provide us) and it will be simpler to provide you with an example using lxml.
   Pete
On 11/15/2022 8:48 PM, 吴煊 via Tech-talk wrote:
Many thanks for all your tips. It seems that phoebusgen is used to generate widgets.I need to write pv value into a xml file, so using etree maybe better. That would be great if there was an example.
Xuan
    -----原始邮件-----
    *发件人:*"Tynan Ford" <[email protected]>
    *发送时间:*2022-11-16 00:56:24 (星期三)
    *收件人:* "Liu, Wanming" <[email protected]>
    *抄送:* "吴煊" <[email protected]>, "kasemir, kay" <[email protected]>, tech-talk <[email protected]>
    *主题:* Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file
    I would not necessarily recommend doing this but you can see an example (exampleInPhoebus files) of creating XML file in jython here: https://github.com/als-epics/phoebusgen/tree/master/examples <https://github.com/als-epics/phoebusgen/tree/master/examples>
    On Tue, Nov 15, 2022 at 8:36 AM Liu, Wanming via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
        The bob file is a xml file.  So you can use etree from lxml package to manipulate the file with python. ____
        __ __
        *From:* Tech-talk <[email protected] <mailto:[email protected]>> *On Behalf Of *?? via Tech-talk
        *Sent:* Monday, November 14, 2022 7:58 PM
        *To:* kasemir, kay <[email protected] <mailto:[email protected]>>
        *Cc:* tech-talk <[email protected] <mailto:[email protected]>>
        *Subject:* Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file____
        __ __
        I'm sorry I didn't make myself clear. I wish to know how to create and write XML file using jython/python script in phoebus? Is there a way to find and replace charactors especially pv_names in xxx.bob file? ____
        Xuan ____
            -----原始邮件-----
            *发件人:*"Kasemir, Kay" <[email protected] <mailto:[email protected]>>
            *发送时间:*2022-11-14 22:27:56 (星期一)
            *收件人:* tech-talk <[email protected] <mailto:[email protected]>>, "吴煊" <[email protected] <mailto:[email protected]>>
            *抄送:*
            *主**题:* Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file____
             > Is there "Find/Replace" function still in phoebus? It's very useful for replacing pv names or other things in CSS. Another question I'd like to ask:how to create and write XML file in phoebus? I haven't see it in display builder examples. Any advice or suggestions will be grately appretiated ____
            __ __
            __ __
            Yes, one advantage of the XML file format is that it allows creating or modifying theses files outside of the graphical editor. ____
            We don't try to include a complete XML editor in phoebus, but you can easily add an OS-specific editor to the context menu so that you can then open a display file from the phoebus file browser via the context menu. ____
            __ __
            For example, on Linux you can add a reference to the plain "gedit" text editor like this, so it can then be used to open *.bob or *.opi files and for example perform PV name replacements:____
            __ __
            org.phoebus.framework.workbench/external_app_text=Text Editor,txt|dat|tab|py|ini|def|db|xml|xsl|css|cmd|sh|st|log|out|md|tex|shp|bob|opi|pvs|edl,gedit____
            __ __
            You could also register VS code or another more XML-aware editor just for *.bob like that. ____
            __ __
            __ __
            For a general python package that generates display files outside of phoebus, see https://github.com/als-epics/phoebusgen <https://github.com/als-epics/phoebusgen>____
            __ __
            __ __
            -Kay ____
            __ __
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
      Education is the one thing for which people
         are willing to pay yet not receive.
Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file Kasemir, Kay via Tech-talk
RE: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file Liu, Wanming via Tech-talk
Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file Tynan Ford via Tech-talk
Re: Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
Prev: Re: Epics Archiver Appliance requests and DST/Timezones Pete Jemian via Tech-talk
Next: RE: Epics Archiver Appliance requests and DST/Timezones Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
Next: Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
