1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: EPICS startup script st.cmd on vxWorks warning message
From: whitetiger1123 via Tech-talk <[email protected]>
Date: Wed, 23 Nov 2022 17:40:17 +0900
Hello all,
While running EPICS startup script st.cmd on vxWorks for an app that was made successfully, I am getting following error:
[VxWorks Boot]: @
boot device          : geisc
unit number          : 0
processor number     : 0
host name            : host
file name            : /home/test/work2/vxconf/default/vxWorks
inet on ethernet (e) : 10.4.49.69:ffffff00
host inet (h)        : 10.4.49.170
gateway inet (g)     : 10.4.49.99
user (u)             : test
ftp password (pw)    : test
flags (f)            : 0x0
startup script (s)   : host:/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd
Loading... 2457184
Starting at 0x100000...
Target Name: vxTarget
Adding 7851 symbols for standalone.
      ]]]]]]]]]]]  ]]]]     ]]]]]]]]]]       ]]              ]]]]         (R)
 ]]]]]]]]]]]]]]]]]]]]]]]]]]]]]       Development System
 ]]]]]]]]]]]]]]]]]]]]]]]]]]]       VxWorks 6.9
 ]]]]]]]]]]]]]]]]]]]]]]]]]]       KERNEL: WIND version 2.13
 ]]]]]]]]]]]]]]]]]]]]]]]]]       Copyright Wind River Systems, Inc., 1984-2011
 CPU: Motorola MVME6100-0173 - MPC 7457.  Processor #0.
 Memory Size: 0x40000000 (1024Mb).  BSP version 6.9/0.
 Created: Nov 11 2022, 13:44:33
 ED&R Policy Mode: Deployed
 WDB Comm Type: WDB_COMM_END
 WDB: Agent Disabled.
Executing startup script 'host:/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd'...
## Example vxWorks startup file
## The following is needed if your board support package doesn't at boot time
## automatically cd to the directory containing its startup script
#cd "/home/USERNAME/epics/iocs/omsIOC/iocBoot/iocOms"
cd "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms"
value = 0 = 0x0
< cdCommands
startup = "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms"
New symbol "startup" added to kernel symbol table.
startup = 0x44f7f50: value = 72359072 = 0x4501ca0
putenv("IOC=iocOms")
value = 0 = 0x0
top = "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC"
New symbol "top" added to kernel symbol table.
top = 0x4501c20: value = 72359296 = 0x4501d80 = top + 0x160
putenv("TOP=/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC")
value = 0 = 0x0
topbin = "/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/bin/vxWorks-ppc32"
New symbol "topbin" added to kernel symbol table.
topbin = 0x4501ec0: value = 72359696 = 0x4501f10 = topbin + 0x50
motor = "/home/test/epics/synApps_6_1/support/motor-R7-1"
New symbol "motor" added to kernel symbol table.
motor = 0x4501e90: value = 72359856 = 0x4501fb0 = topbin + 0xf0
putenv("MOTOR=/home/test/epics/synApps_6_1/support/motor-R7-1")
value = 0 = 0x0
motorbin = "/home/test/epics/synApps_6_1/support/motor-R7-1/bin/vxWorks-ppc32"
New symbol "motorbin" added to kernel symbol table.
motorbin = 0x44cf4f0: value = 72327040 = 0x44f9f80
asyn = "/home/test/epics/synApps_6_1/support/asyn-R4-36"
New symbol "asyn" added to kernel symbol table.
asyn = 0x44f9fe0: value = 72367504 = 0x4503d90
putenv("ASYN=/home/test/epics/synApps_6_1/support/asyn-R4-36")
value = 0 = 0x0
asynbin = "/home/test/epics/synApps_6_1/support/asyn-R4-36/bin/vxWorks-ppc32"
New symbol "asynbin" added to kernel symbol table.
asynbin = 0x4503e80: value = 72367824 = 0x4503ed0 = asynbin + 0x50
sncseq = "/home/test/epics/synApps_6_1/support/seq-2-2-6"
New symbol "sncseq" added to kernel symbol table.
sncseq = 0x4503f30: value = 72368000 = 0x4503f80 = sncseq + 0x50
putenv("SNCSEQ=/home/test/epics/synApps_6_1/support/seq-2-2-6")
value = 0 = 0x0
sncseqbin = "/home/test/epics/synApps_6_1/support/seq-2-2-6/bin/vxWorks-ppc32"
New symbol "sncseqbin" added to kernel symbol table.
sncseqbin = 0x4503fc0: value = 72364144 = 0x4503070 = 'p'
busy = "/home/test/epics/synApps_6_1/support/busy-R1-7-2"
New symbol "busy" added to kernel symbol table.
busy = 0x44cb710: value = 72364560 = 0x4503210
putenv("BUSY=/home/test/epics/synApps_6_1/support/busy-R1-7-2")
value = 0 = 0x0
busybin = "/home/test/epics/synApps_6_1/support/busy-R1-7-2/bin/vxWorks-ppc32"
New symbol "busybin" added to kernel symbol table.
busybin = 0x4503fe0: value = 72364848 = 0x4503330 = '0'
ipac = "/home/test/epics/synApps_6_1/support/ipac-2-15"
New symbol "ipac" added to kernel symbol table.
ipac = 0x4503390: value = 72365024 = 0x45033e0 = ipac + 0x50
putenv("IPAC=/home/test/epics/synApps_6_1/support/ipac-2-15")
value = 0 = 0x0
epics_base = "/home/test/epics/base-3.15.6"
New symbol "epics_base" added to kernel symbol table.
epics_base = 0x45034b0: value = 72365312 = 0x4503500 = epics_base + 0x50
putenv("EPICS_BASE=/home/test/epics/base-3.15.6")
value = 0 = 0x0
epics_basebin = "/home/test/epics/base-3.15.6/bin/vxWorks-ppc32"
New symbol "epics_basebin" added to kernel symbol table.
epics_basebin = 0x45035d0: value = 72365616 = 0x4503630 = '0' = epics_basebin + 0x60
< ../nfsCommands
#Instructions for creating and using a real nfsCommands file
# in order to use nfs do the following:
# 1) Create hostAdd and nfsMount commands for each nfs server
# 2) In each st.cmd file add the following two commands BEFORE any load commands
#    ../nfs.cmd
#    cd "<iocname>
# The hostAdd command has the form:
# hostAdd("<host>","xxx.xxx.xxx.xxx")
# The vxWorks nfsMount command has the form:
# nfsMount("<host>")
# You can also mount subdirectories as follows:
# nfsMount("<host>", "/xxx/xxx/xxx", "/xxx")
# For example assume
# host is mercury with inet address 155.77.2.56
# You want to mount the directory (which is a file system of mercury)
# /home/mercury5/iocinfo
#    as
# /iocinfo
# The commands would be
# hostAdd("mercury","155.77.2.56")
# nfsMount("mercury","/home/mercury5/iocinfo","/iocinfo")
cd topbin
value = 0 = 0x0
## You may have to change oms to something else
## everywhere it appears in this file
ld 0,0, "oms.munch"
BSP routine sysAtReboot() not found, epicsExit() will not be
called by reboot.  For reduced functionality, call
    rebootHookAdd(epicsExitCallAtExits)
value = 72413200 = 0x450f010
cd top
value = 0 = 0x0
dbLoadDatabase "dbd/oms.dbd"
value = 0 = 0x0
oms_registerRecordDeviceDriver pdbbase
value = 0 = 0x0
cd startup
value = 0 = 0x0
## motorUtil (allstop & alldone)
dbLoadRecords("$(MOTOR)/db/motorUtil.db", "P=oms:")
value = 0 = 0x0
## Support for the OMS MAXv (VxWorks shell or iocsh)
#< MAXv.cmd
#< MAXv.iocsh
## Support for the OMS VME85
#< VME58.cmd
## Support for the OMS VME8 and VME44
#< VME8.cmd
## Support for the OMS PC68 and PC78 (requires asyn)
#< PC68.cmd
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Oct  7 2022
WARNING: OS Clock time was read before being set.
Using 1990-01-02 00:00:00.000000 UTC
iocInit: Time provider has not yet synchronized.
value = 0 = 0x0
motorUtilInit("oms:")
value = 0 = 0x0
# Boot complete
Done executing startup script 'host:/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd'.
I hope you understand Iam new to the world of EPICS. Casual I’ve been trying to understand them for 3 days. From there to before he knew nothing of them.
I hope you can help.
Thanks and regards.
Re: EPICS startup script st.cmd on vxWorks warning message Andrew Johnson via Tech-talk
Prev: Multiple pointers to /usr/lib/epics Daykin, Evan via Tech-talk
Next: Re: Multiple pointers to /usr/lib/epics Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Multiple pointers to /usr/lib/epics Michael Davidsaver via Tech-talk
Next: Re: EPICS startup script st.cmd on vxWorks warning message Andrew Johnson via Tech-talk
