1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: EPICS startup script st.cmd on vxWorks warning message
From: Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
To: whitetiger1123 <holyeongbaeg at gmail.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 23 Nov 2022 11:28:45 -0600
On 11/23/22 2:40 AM, whitetiger1123 via Tech-talk wrote:
Hello all,
While running EPICS startup script st.cmd on vxWorks for an app that was made successfully, I am getting following error:
[VxWorks Boot]: @
boot device          : geisc
unit number          : 0
processor number     : 0
host name            : host
file name            : /home/test/work2/vxconf/default/vxWorks
inet on ethernet (e) : 10.4.49.69:ffffff00
host inet (h)        : 10.4.49.170
gateway inet (g)     : 10.4.49.99
user (u)             : test
ftp password (pw)    : test
flags (f)            : 0x0
startup script (s)   : host:/home/test/epics/synApps_6_1/support/motor-R7-1/modules/motorOms/iocs/omsIOC/iocBoot/iocOms/st.cmd
Loading... 2457184
Starting at 0x100000...
Snipped ...
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Oct  7 2022
WARNING: OS Clock time was read before being set.
Using 1990-01-02 00:00:00.000000 UTC
iocInit: Time provider has not yet synchronized.
value = 0 = 0x0
The IOC appears to have started normally so it should work. The only issue will be that it wasn't able to set its time-of-day clock, so the timestamps that accompany any data over Channel Access will be dated from January 1990. Unless you explicitly configure it the VxWorks clock code in EPICS will try to synchronize the OS clock time with an NTP server running on the boot host. If your boot host doesn't run an NTP server such as ntpd or chrony (or the server isn't configured to make the time available over the network) you can give the IOC the IP address for another NTP server like this, replacing xx with the appropriate number for that server:
putenv "EPICS_TS_NTP_INET=10.4.49.xx"
That line should be added near the top of your st.cmd script, preferably before the line that loads the oms.munch file. Alternatively you could install an NTP server on your boot host and make sure that it can be access through any firewall that is running there, then you won't need the line above.
There are a few commands that you can run to look at the state of the EPICS time synchronization system: generalTimeReport(1) will list the time providers that have been registered with it and what their current state is. NTPTime_Report(1) will give more information about the NTP time synchronization task, and ClockTime_Report(1) tells you about the task that synchronizes the OS clock — both of those should also appear in the generalTimeReport output but with different information. You can omit the (1) parameters to those commands which will then show less detail.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
EPICS startup script st.cmd on vxWorks warning message whitetiger1123 via Tech-talk
Prev: Re: Multiple pointers to /usr/lib/epics Ralph Lange via Tech-talk
Next: Re: Multiple pointers to /usr/lib/epics Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: EPICS startup script st.cmd on vxWorks warning message whitetiger1123 via Tech-talk
Next: Illegal field value PV: oms:m1 motor_init_record_com(): card does not exist! motorOMS st.cmd error whitetiger1123 via Tech-talk
ANJ, 24 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
