Hi Andrew,
On 11/25/22 12:34 PM, Wang, Andrew via
Tech-talk wrote:
I
was wondering about the use of the dpvt pointer in a subroutine
that the aSub record uses when it is processed. My understanding
is that the dpvt pointer is used for device support, but I was
wondering if it can also be used as an alternative to static
variables
Yes, the subroutine record types don't have any device support
associated with them, so your subroutines are welcome to use that
pointer for themselves if they wish. Record subroutines have to be
re-entrant if they are used by more than one record instance, so
static variables are not as useful in them as shown by your example
— you would need to protect any accesses to static variables with an
epicsMutex if you did want to use them as such since two subroutines
could get processed by different threads at the same time, leading
to a potential race condition.
An additional related question: Suppose for
device support, dpvt pointer points to a struct, which has a
special free function associated with it (the struct might contain
member variables that are dynamically allocated). Where can that
be called so that there is no memory leaks from the IOC?
The aSub record type has a function-pointer field prec->cadr
which your subroutine can point to a cleanup function. It will be
called (and passed prec) and then prec->cadr set to NULL whenever
the SNAM field of the record gets changed.
Note that the cadr won't be called when the IOC shuts down, for that
you would need to register an epicsAtExit() routine to be called
when the process exits. However if it's just freeing memory that
you're worried about the IOC process exiting will normally return
all of the process RAM back to the OS automatically; I would only
worry about that when embedding the IOC into and running it within
the context of another process.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Using DPVT for non-device support purposes Wang, Andrew via Tech-talk
LabJack R3-0 available Mark Rivers via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 25 Nov 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
