1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: LabJack R3-0 available
Date: Fri, 25 Nov 2022 20:46:18 +0000
LabJack is an EPICS module that supports LabJack T-series I/O modules.
Previous releases of the LabJack module just used the EPICS Modbus driver, and only provided basic support.
This release is a driver derived from asynPortDriver, and it supports the more advanced features of the LabJack devices.
The driver supports the 4 current T-series modules:
LabJack T4: https://labjack.com/products/labjack-t4
- 4 single-ended analog inputs
  - +- 10V range
  - 12-bit
  - Up to 50 kHz total streaming input rate, i.e. 1 channel at 50 kHz, 2 channels at 25 kHz, etc.
- Up to 8 additional analog inputs (0-2.5 V range, 12-bit).  These can also be configured as digital I/O bits.
- 2 analog outputs
  - 0-5V range
  - 10-bit
  - Up to 50 kHz streaming output rate
- 20 digital I/O bits
  - Rach configurable as input or output.
  - 8 of these can configured as 0-2.5V analog inputs.
- $245
LabJack T7: https://labjack.com/products/t7
- 14 single-ended / 7 differential analog inputs
  - Programmable range (+-10V, +-1V, +-0.1V, +-0.01V)
  - 16-bit
  - Up to 100 kHz total streaming input rate, i.e. 1 channel at 100 kHz, 2 channels at 50 kHz, etc.
- 2 analog outputs
  - 0-5V range
  - 12-bit
  - Up to 100 kHz streaming output rate
- 23 digital I/O bits
  - Each configurable as input or output.
- $520
LabJack T7-Pro: https://labjack.com/products/labjack-t7-pro
- Same as the T7 except that each analog input can be software switched between 16-bit and 24-bit ADC, trading off resolution for speed.
- In 24-bit mode the ADCs support 9 types of thermocouple inputs.
- $750
LabJack T8: https://labjack.com/products/t8
- 8 differential analog inputs
  - 11 input ranges from +-11V to +-0.15 V
  - 24-bit sigma/delta ADC
  - Supports 9 types of thermocouple inputs
  - Up to 40 kHz streaming input per channel, i.e. up to 320 kHz total scanning rate.
- 2 analog outputs
  - 0-10V range
  - 16-bit
  - Up to 40 kHz streaming output rate
- 23 digital I/O bits, each configurable as input or output.
- $1,400
Github repository: https://github.com/epics-modules/labjack
Release notes: https://github.com/epics-modules/LabJack/blob/master/RELEASE.md
Documentation: https://epics-modules.github.io/LabJack/
Prev: Re: Using DPVT for non-device support purposes Andrew Johnson via Tech-talk
Next: Problem downloading from sequenzer repo Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
