1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: manage-procs and conserver: use cases?
From: Kuldeep Joshi via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 28 Nov 2022 12:59:29 +0000
Hello,
I could add and run two procServ processes using manage-proc add.
I have the following queries
1) How do I add a log file or keep a port for logging with manage-procs. How do I specify the port type (tcp or uds)
2) How to link conserver with the procServ processes created by manage-procs
3) The option manage-procs -write-procs-cf -f 'filename' is generating a file with connection type as uds. How do I use this file to configure conserver service
4) I wanted to create a system service however wanted to access/manage it from the user account without using sudo. Is it possible? basically for 'manage-procs attach'. As I see that the manage-proc services created with sudo can only be listed by 'sudo manage-proc list'. Just 'manage-procs list' does not list the system processes
Thank you and regards,
Kuldeep
Prev: Problem downloading from sequenzer repo Jörn Dreyer via Tech-talk
Next: Re: How to: IOC reading information from file? Nariyoshi, Pedro via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Problem downloading from sequenzer repo Andrew Johnson via Tech-talk
Next: Using one substitution file for multiple template files Wang, Andrew via Tech-talk
