1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Problem downloading from sequenzer repo
From: Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Tue, 29 Nov 2022 10:24:58 -0600
On 11/29/22 5:59 AM, Birke, Thomas via Tech-talk wrote:
Hi all,
The problem is solved and the correct certificate chain has been installed.
Confirmed, thank-you!
- Andrew
On 29. Nov 2022, at 09:58, Birke, Thomas via Tech-talk <tech-talk at aps.anl.gov> wrote:
Thanks for the heads up and the detailed info.
Our web-admin is taking care of fixing the problem ASAP.
Best,
Thomas
Thomas Birke
Institute "Accelerator Physics" / Department "Accelerator Operation and Technology" / BE-IA-AOT
Accelerator Control Systems Group / ACS
Fon +49 30 8062-14934
Mobile +49 172 6738140
Fax +49 30 8062-14980
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
www.helmholtz-berlin.de
On 28. Nov 2022, at 19:03, Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov> wrote:
On 11/28/22 09:12, Andrew Johnson via Tech-talk wrote:
On 11/28/22 3:14 AM, Jörn Dreyer via Tech-talk wrote:
I encountered a problem while downloading the sequenzer from its repo either
using darcs or git. Both fail with an SSL error telling that the certificate is
invalid.
I've been having similar access problems since last week, different versions of git give me either
fatal: unable to access 'https://www-csr.bessy.de/control/SoftDist/sequencer/repo/branch-2-2.git/': SSL certificate problem: unable to get local issuer certificate
or
fatal: unable to access 'https://www-csr.bessy.de/control/SoftDist/sequencer/repo/branch-2-2.git/': Peer's Certificate issuer is not recognized.
The currently advertised certificate was issued on 31 October.
I think www-csr.bessy.de may still be serving up an old version
of an intermediate certificate ("GEANT OV RSA CA 4").
For some reason firefox is quite happy, and shows a certificate
chain with "GEANT OV RSA CA 4" issued by "USERTrust RSA Certification Authority".
However, running "openssl s_client -connect www-csr.bessy.de:443"
shows a different root..
Certificate chain
0 s:C = DE, ST = Berlin, O = Helmholtz-Zentrum Berlin f\C3\BCr Materialien und Energie GmbH, CN = www-csr.bessy.de
  i:C = NL, O = GEANT Vereniging, CN = GEANT OV RSA CA 4
1 s:C = DE, O = Verein zur Foerderung eines Deutschen Forschungsnetzes e. V., OU = DFN-PKI, CN = DFN-Verein Global Issuing CA
  i:C = DE, O = Verein zur Foerderung eines Deutschen Forschungsnetzes e. V., OU = DFN-PKI, CN = DFN-Verein Certification Authority 2
2 s:C = DE, O = Verein zur Foerderung eines Deutschen Forschungsnetzes e. V., OU = DFN-PKI, CN = DFN-Verein Certification Authority 2
  i:C = DE, O = T-Systems Enterprise Services GmbH, OU = T-Systems Trust Center, CN = T-TeleSec GlobalRoot Class 2
3 s:C = DE, O = T-Systems Enterprise Services GmbH, OU = T-Systems Trust Center, CN = T-TeleSec GlobalRoot Class 2
Complexity comes for free, Simplicity you have to work for.
Problem downloading from sequenzer repo Jörn Dreyer via Tech-talk
Re: Problem downloading from sequenzer repo Andrew Johnson via Tech-talk
Re: Problem downloading from sequenzer repo Michael Davidsaver via Tech-talk
Re: Problem downloading from sequenzer repo Birke, Thomas via Tech-talk
Prev: Re: How to: IOC reading information from file? Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: How to: IOC reading information from file? Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Problem downloading from sequenzer repo Birke, Thomas via Tech-talk
Next: manage-procs and conserver: use cases? Kuldeep Joshi via Tech-talk
ANJ, 29 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
