1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Compiling base on Rocky Linux 9
From: "Wang Xiaoqiang \(PSI\) via Tech-talk" <tech-talk at aps.anl.gov>
To: Ernesto Paiser <epaiser at sigray.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 5 Dec 2022 18:39:30 +0000
Try the latest 3.15 release, https://epics.anl.gov/base/R3-15/9.php
> On 5 Dec 2022, at 19:27, Ernesto Paiser via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Hello guys,
> I'm having trouble in compiling EPICS base 3.15.6 in rocky linux 9.
> I believe it should be something related to the enforcement rules on gcc compiler.
> Someone knows how tho workaround this?
> Thank you!!
> In file included from ../../../../../../src/ca/legacy/pcas/generic/caServer.cc:21:
> ../../../../../../src/ca/legacy/pcas/generic/caServerI.h: At global scope:
> ../../../../../../src/ca/legacy/pcas/generic/caServerI.h:91:5: error: ‘class tsDLList<ioBlocked> tsDLList<ioBlocked>::tsDLList’ is private within this context
>   91 |     tsDLList < casStrmClient > clientList;
> In file included from ../../../../../../src/ca/legacy/pcas/generic/caServerI.h:33,
> ../../../../../../src/ca/legacy/pcas/generic/ioBlocked.h:43:7: note: declared private here
>   43 | class ioBlockedList : private tsDLList<ioBlocked> {
> ../../../../../../src/ca/legacy/pcas/generic/caServerI.h:92:5: error: ‘class tsDLList<ioBlocked> tsDLList<ioBlocked>::tsDLList’ is private within this context
>   92 |     tsDLList < casIntfOS > intfList;
> make[2]: *** [../../../../../../configure/RULES_BUILD:236: caServer.o] Error 1
> make[2]: Leaving directory '/opt/epics/R3.15.6/base-3.15.6/src/ca/legacy/pcas/build/O.linux-x86_64'
> make[1]: *** [../../../../../configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
> make[1]: Leaving directory '/opt/epics/R3.15.6/base-3.15.6/src/ca/legacy/pcas/build'
> make: *** [../../../../configure/RULES_DIRS:84: build.install] Error 2
> Ernesto Paiser - Senior Controls Engineer
> Sigray, Inc.
> 5750 Imhoff Dr, Concord, CA 94520
> United States
> epaiser at sigray.com <mailto:epaiser at sigray.com>
> +1-650-503-3410
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Re: Compiling base on Rocky Linux 9 Ernesto Paiser via Tech-talk
Prev: Compiling base on Rocky Linux 9 Ernesto Paiser via Tech-talk
Next: Re: Compiling base on Rocky Linux 9 Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: Compiling base on Rocky Linux 9 Ernesto Paiser via Tech-talk
ANJ, 05 Dec 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
