1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Compiling base on Rocky Linux 9
From: Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
To: Ernesto Paiser <epaiser at sigray.com>, tech-talk at aps.anl.gov
Date: Mon, 5 Dec 2022 12:40:24 -0600
Hi Ernesto,
Have you tried building R3.15.9 or EPICS 7.0.7 at all on Rocky 9? What GCC version does that come with?
I'm not sure whether we have made changes since then to fix that, but 3.15.6 is now 4 years old. You might be able to add something like
ARCH_DEP_CXXFLAGS = -std=c++11
to your configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64 file to tell GCC to back down to an earlier C++ standard.
- Andrew
On 12/5/22 12:27 PM, Ernesto Paiser via Tech-talk wrote:
Hello guys,
I'm having trouble in compiling EPICS base 3.15.6 in rocky linux 9.
I believe it should be something related to the enforcement rules on gcc compiler.
Someone knows how tho workaround this?
Thank you!!
In file included from ../../../../../../src/ca/legacy/pcas/generic/caServer.cc:21:
../../../../../../src/ca/legacy/pcas/generic/caServerI.h: At global scope:
../../../../../../src/ca/legacy/pcas/generic/caServerI.h:91:5: error: ‘class tsDLList<ioBlocked> tsDLList<ioBlocked>::tsDLList’ is private within this context
   91 |     tsDLList < casStrmClient > clientList;
In file included from ../../../../../../src/ca/legacy/pcas/generic/caServerI.h:33,
../../../../../../src/ca/legacy/pcas/generic/ioBlocked.h:43:7: note: declared private here
   43 | class ioBlockedList : private tsDLList<ioBlocked> {
../../../../../../src/ca/legacy/pcas/generic/caServerI.h:92:5: error: ‘class tsDLList<ioBlocked> tsDLList<ioBlocked>::tsDLList’ is private within this context
   92 |     tsDLList < casIntfOS > intfList;
make[2]: *** [../../../../../../configure/RULES_BUILD:236: caServer.o] Error 1
make[2]: Leaving directory '/opt/epics/R3.15.6/base-3.15.6/src/ca/legacy/pcas/build/O.linux-x86_64'
make[1]: *** [../../../../../configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/opt/epics/R3.15.6/base-3.15.6/src/ca/legacy/pcas/build'
make: *** [../../../../configure/RULES_DIRS:84: build.install] Error 2
Complexity comes for free, Simplicity you have to work for.
Compiling base on Rocky Linux 9 Ernesto Paiser via Tech-talk
Prev: Re: Compiling base on Rocky Linux 9 Wang Xiaoqiang (PSI) via Tech-talk
Next: RE: Eurotherm2604 modbus support Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: Re: Compiling base on Rocky Linux 9 Ernesto Paiser via Tech-talk
Next: Problem of using CS-Studio (Phoebus) liuxiaomin via Tech-talk
ANJ, 07 Dec 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
