I'm working with a device that returns multiple integer values in
response to queries. These values need to be scaled by 0.1 to have the
correct units.
The query function in the protocol file looks like this:
getLedIntensity {
out "ip?";
in
"%(\$1:LED1:intensity_RBV)u,%(\$1:LED2:intensity_RBV)u,%(\$1:LED3:intensity_RBV)u";
This is how the ai records are configured:
record(ai, "$(P)$(R):LED$(N):intensity_RBV") {
field(DESC, "LED $(N) intensity RBV")
field(PREC, "1")
# The raw value is in tenths of a percent
field(LINR, "NO CONVERSION")
field(ASLO, "0.1")
field(HOPR, "100.0")
field(LOPR, "0.0")
When the intensities are queried, the ai records have VAL fields that
have not been scaled by the ASLO value.
Does the redirection-to-record feature of streamDevice circumvent the
RVAL conversion for ai records? If not, is there something obviously
wrong with this approach?
This support resides in an older IOC that is using base-3.15.6 and
StreamDevice 2-8-9.
Thanks ahead of time.
Kevin
My working hours may not be your working hours. Please do not
feel obligated to reply outside of your normal work schedule.
- Re: StreamDevice redirection to ai record with ASLO question Zimoch Dirk (PSI) via Tech-talk
Re: Ways to know if instrument connected via TCP/IP through StreamDevice has lost connection Kuldeep Joshi via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
