1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: EPICS, PostgreSQL, Archive Engine: doubts about how to use them
From: Oscar Ibañez via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, Abdalla Ahmad <[email protected]>
Date: Thu, 12 Jan 2023 21:43:09 +0100
Hi Kay and Abdalla,
Thank you for your explanations. I didn't know that the software was in the nightly repository.
Óscar
El 12/01/2023 a las 14:11, Kasemir, Kay escribió:
To store the history of samples, you have at least three options:
a) Run the phoebus data browser to sample live data from channel access or PV access, and then "export" the data from the plot. That only captures what was sampled while the data browser was running. You could similarly run "camonitor some_pv_name | tee archive.dat" to capture data into a file.
b) Or you run some service that takes samples in the background by using the archive engine for writing to Oracle/MySQL/Postgres/Timescaledb. That binary is the "archive-engine.zip" on https://controlssoftware.sns.ornl.gov/css_phoebus/nightly/ (which now combines what used to be a separate archive config tool and archive engine).
c) Or you use that archive appliance, https://slacmshankar.github.io/epicsarchiver_docs/, a similar service which uses its own binary data file format instead of a relational database.
To then look at the data, you can again use the phoebus data browser (after you configure phoebus to look at either Oracle/MySQL/Postgres/Timescaledb or the archive appliance), or you go directly to Oracle/MySQL/Postgres/Timescaledb or the archive applicance web service.
From: Tech-talk <[email protected]> on behalf of Abdalla Ahmad via Tech-talk <[email protected]>
Sent: Thursday, January 12, 2023 3:46 AM
To: Oscar Ibañez <[email protected]>
Cc: [email protected] <[email protected]>
Subject: [EXTERNAL] RE: EPICS, PostgreSQL, Archive Engine: doubts about how to use them
Hello Oscar
Many years ago, we happened to use the RDB archive engine so I will give you what I remember from that time. The RDB archive engine is a server application installed on a separate server. Once configured, the engine will start save samples from the configured PVs. The role of CSS/Phoebus is that it contains the data browser tool. The data browser tool connects to the archive engine via the preferences and configurations you mentioned, then you can view archived data on the data browser tool. The archive engine is a java application consisting of two tools, the config tool and the engine. The config tool is used to load PV configuration into the RDB and the engine tool is used to start the archiver itself. Unfortunately I could not find download links for it.
Hope this helps.
Abdalla.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Oscar Ibañez via Tech-talk
Sent: Thursday, January 12, 2023 11:03 AM
To: [email protected]
Subject: EPICS, PostgreSQL, Archive Engine: doubts about how to use them
I am trying to set up a PostgreSQL RDMS to work together with EPICS to save some PV values. However, I am having doubts about how to do it, since the process is not clear to me.
First of all, I installed EPICS and I downloaded Phoebus. Both are running with no problem. In addition, I installed PostgreSQL. It seems to work fine. Then, I tried to learn how to connect EPICS and PostgreSQL, and I ended up reading Phoebus documentation about the RDB Archive Engine, and that was the point when I did no understand what I was doing.
https://gcc02.safelinks.protection.outlook.com/?url="">
The document says that I need to download the archive engine from:
But I can't find any archive engine in that place.
In addition, I am confused about the rol of Phoebus in this problem. Why do I need to set up any preference in the Phoebus configuration to use the Archive Engine? Phoebus is just a software to create and to display graphical screen to monitor/check the control system. If I run the Archive Engine, that software will save PV values in the PostgreSQL tables that I want. So, I don't understand the relationship between Phoebus and the Archive Engine, since the documentation is in the CSS web.
Any help would be useful.
Regards.
Óscar
EPICS, PostgreSQL, Archive Engine: doubts about how to use them Oscar Ibañez via Tech-talk
RE: EPICS, PostgreSQL, Archive Engine: doubts about how to use them Abdalla Ahmad via Tech-talk
Re: EPICS, PostgreSQL, Archive Engine: doubts about how to use them Kasemir, Kay via Tech-talk
Prev: RE: [External] Kniel Power Supply Leblanc, Gregory via Tech-talk
Next: How to use epicsThreadSetCPUaffinity in epics 7.0.4 김대영 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: EPICS, PostgreSQL, Archive Engine: doubts about how to use them Kasemir, Kay via Tech-talk
