1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Weird behaviour in wait=True when using epics.Motor.get(something, something, wait=True)
From: Matt Newville via Tech-talk <[email protected]>
To: "Marco A. Barra Montevechi Filho" <[email protected]>
Cc: SWC <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 17 Jan 2023 10:30:21 -0600
To follow up on Torsten's comment, the default timeout for a `epics.Motor.put()` is 10 seconds.   The behavior you are seeing could be because the processing of setting CNEN takes more than that 10 seconds.
Giving a longer timeout to the `put()` might clarify what is happening.
On Mon, Jan 16, 2023 at 3:27 PM Marco A. Barra Montevechi Filho via Tech-talk <[email protected]> wrote:
Good evening all.
Im working with the same IOC i was using here: https://epics.anl.gov/tech-talk/2023/msg00020.php. Now i loaded some motor records in it and am trying to control the IOC via pyepics. Something weird is happening.
i made the following python script:
import epics
a = epics.Motor("MGN:B:E873A:DIAG:X:m1")
a.put("CNEN", 1,wait=True)
assert a.get("CNEN")==1
And i frequently get assertion errors. What is happening? Shouldn't wait=True prevent this? How do i debug this?
Even more weird: i tried debugging this with callbacks:
import epics, time
a = epics.Motor(
def printvalue(**kwargs):
    print(kwargs["value"])
b = epics.PV("MGN:B:E873A:DIAG:X:m1.CNEN")
b.add_callback(printvalue)
c = 1
while True:
    c=1-c
    print("#####")
    a.put("CNEN",c)
    time.sleep(0.1)
And i get prints like:
1
0
1
0
Why do i sometimes get two callbacks and sometimes get only one? Thanks in advance for any help.
I append the IOC initialization log and the substitutions file it loads:
INIT LOG:
#!/usr/local/epics/apps/pigcs2IOC/bin/linux-x86_64/pigcs2
< /usr/local/epics/apps/pigcs2IOC/iocBoot/iocPIGCS2/envPaths
epicsEnvSet("IOC","iocPIGCS2")
epicsEnvSet("TOP","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC")
epicsEnvSet("SUPPORT","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support")
epicsEnvSet("ASYN","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/asyn-R4-36")
epicsEnvSet("STREAM","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/StreamDevice-2-8-9")
epicsEnvSet("CALC","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/calc-R3-7-3")
epicsEnvSet("RECCASTER","/usr/local/epics-nfs/apps/recsync/1.4_epics_3.15/client")
epicsEnvSet("SNCSEQ","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/seq-2-2-6")
epicsEnvSet("BUSY","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/busy-R1-7-2")
epicsEnvSet("IPAC","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/ipac-2-15")
epicsEnvSet("MOTOR","/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1")
epicsEnvSet("EPICS_BASE","/usr/local/epics-nfs/base/R3.15.6")
cd "/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC"
## Set up environment
epicsEnvSet("DEV","MGN:B:E873A:DIAG:X:")
epicsEnvSet("BL", "MGN:B:E873A:DIAG:X")
epicsEnvSet("IOCNAME", "MGN-B-E873A-DIAG-X")
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES",15728645)
# protocol file paths
epicsEnvSet ("STREAM_PROTOCOL_PATH", ".:/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/db")
dbLoadDatabase "dbd/pigcs2.dbd"
pigcs2_registerRecordDeviceDriver pdbbase
cd "/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC/iocBoot/iocPIGCS2"
## motorUtil (allstop & alldone)
dbLoadRecords("/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/db/motorUtil.db", "P=MGN:B:E873A:DIAG:X:")
# < PI_GCS2.cmd
# PI GCS2 support
dbLoadTemplate("/usr/local/epics/apps/config/PIGCS2/e873aX.substitutions")
drvAsynIPPortConfigure("E873_ETH","CDE5B3D.abtlus.org.br:50000",0,0,0)
# Turn on asyn trace
# asynSetTraceMask("E873_ETH",0,3)
# asynSetTraceIOMask("E873_ETH",0,1)
# PI_GCS2_CreateController(portName, asynPort, numAxes, priority, stackSize, movingPollingRate, idlePollingRate)
# # this is the final setup
# PI_GCS2_CreateController("E873", "E873_ETH", 1, 0, 0, 100, 1000)
# speedup debug
PI_GCS2_CreateController("E873", "E873_ETH", 1, 0, 0, 50, 1000)
2023/01/16 18:23:03.949 read from E873_ETH: (c)2016-2020 Physik Instrumente (PI) GmbH & Co. KG, E-873.1AT, 120040762, 03.033
PIasynAxis::PIasynAxis() 0: 1
----------------- axis num: 0 createCLParams() m_szAxisName: 1-------------------
# Turn off asyn trace
# asynSetTraceMask("E873_ETH",0,1)
# asynSetTraceIOMask("E873_ETH",0,0)
# Set end-of-string terminators (port, addr, terminator)
asynOctetSetInputEos("E873_ETH", 0, "\n")
asynOctetSetOutputEos("E873_ETH", 0, "\n")
dbLoadRecords("/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/motor-R7-1/modules/motorPIGCS2-R1-1/iocs/pigcs2IOC/db/PI_Support.db","P=MGN:B:E873A:DIAG:X:,R=m1:,PORT=E873,ADDR=0,TIMEOUT=1")
# asyn record for troubleshooting
dbLoadRecords("/usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/asyn-R4-36/db/asynRecord.db","P=MGN:B:E873A:DIAG:X:,R=asynEth,PORT=E873_ETH,ADDR=0,OMAX=256,IMAX=524288")
# RECSYNC
dbLoadRecords("/usr/local/epics-nfs/apps/recsync/1.4_epics_3.15/client/db/reccaster.db", "P=MGN:B:E873A:DIAG:X:REC:")
# protocol
#dbLoadRecords("$(MOTOR)/db/e873.db", "P=$(DEV),PORT=E873_ETH")
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Sep 27 2021
e873aX.substitutions FILE:
file "$(MOTOR)/motorApp/Db/asyn_motor.db"
pattern
{P,              M,     DTYP,       PORT, ADDR,      DESC,  EGU,  DIR,  VELO,  VBAS,  ACCL,  BDST,  BVEL,  BACC,  MRES,  PREC,  DHLM,  DLLM,  INIT}
{MGN:B:E873A:DIAG:X:,  "m1",  "asynMotor",  "E873",    0,  "Motor 1", mm,  Pos,    1,    0,    .1,    0,      0,    0,   0.000001,  7,     5.0,   -5.0,  ""}
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Marco A. Barra Montevechi Filho via Tech-talk
Prev: EPICS Code-a-thon Collaboration Workshop - Registration Now Open Diamond Events via Tech-talk
Next: Re: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Weird behaviour in wait=True when using epics.Motor.get(something,something,wait=True) Marco A. Barra Montevechi Filho via Tech-talk
